5th Feb 2017, 3:43 pm | #1 |
Dansette Bermuda Mk2 1968
Hi, I have just got my player working since purchasing it a few years ago, can you tell me what the humming noise is when I turn the power on and also the stylus that is fitted is an ST20, is that the correct one?
Thanks, Alan. |
5th Feb 2017, 4:15 pm | #2 |
Re: Dansette Bermuda Mk2 1968
We need to know the cartridge to say if the ST20 is correct, the cartridge could have been replaced at some time in the past. Photo may help.
Can you describe the hum, there at first switch on or after a few minutes? I think the player is valve but if you could confirm if it is transistor or valve that may also help. Others will give better advice than I can but they need information to help. Frank |
5th Feb 2017, 5:02 pm | #3 |
Is the humming loud and does it start as soon as you switch it on?
If yes then the fault is almost certainly caused by failure of the main smoothing capacitor. |
5th Feb 2017, 5:03 pm | #4 |
It is valve.
Edward. |
5th Feb 2017, 7:16 pm | #5 |
Thanks for the quick reply, the hummimng starts has soon as you turn the power on, if the cartridge is the part that the needle sits in, I can't see any identification on it. Alan |
5th Feb 2017, 11:35 pm | #6 |
In which case, could you provide a photo or two?
6th Feb 2017, 8:05 pm | #7 |
The cartridge is an SC11M |
6th Feb 2017, 10:31 pm | #8 |
Cannot help with the stylus.
The humming noise, the player uses a series heater chain for the valves, its possible they are fed from the motor so I can only think it is the motor you can hear. The smoothing/reservoir capacitors mentioned earlier would only start the player humming after the valves warm up. So you will probably need to check the motor and its mounting rubber bushes, unless others have a better suggestion. Take note that this will be a live chassis player, take suitable precautions against electric shocks. Frank |
6th Feb 2017, 10:46 pm | #9 |
That is the correct stylus for that cartridge, however, it's not the original cartridge.
7th Feb 2017, 12:19 pm | #10 |
If the cartridge currently fitted is a BSR SC11M, you can still get replacement styli for these. Are the deck transit screws turned down (as they should be) to reduce vibrations/motor noise transmission?
Edward. |
7th Feb 2017, 4:16 pm | #11 |
24th Sep 2017, 10:05 am | #12 |
Dansette Bermuda Mk 2
When playing an LP record on auto, why does the stylus arm sometimes drop too early and not make contact with the record, also what is the humming sound when switched on and can it be eliminated. Thanks Alan |
24th Sep 2017, 10:49 am | #13 |
If you haven't already, read through this thread: https://www.vintage-radio.net/forum/...ad.php?t=75401
24th Sep 2017, 12:24 pm | #14 |
The stylus set down position can be easily adjusted. Your Thread has a gap of several months. So - is the humming a new type of hum or the same as before? Your player is valved and the we assume the hum starts after warm up.
Edward. |
24th Sep 2017, 4:52 pm | #15 |
Is the hum there with the volume control at minimum.
If so how loud |
