30th Sep 2012, 5:02 pm | #1 |
Grundig TK-121 rewinds, fast forwards but only one reel 'plays'.
I have just purchased a Grundig TK-121. It's pretty beautiful. Everything seems to be working perfectly until I play the thing. Rewind and FF work well (so both reels are moving fine) but when I press play the left reel winds but the right reel sits there (and thus reel goes everywhere). I've opened it up to have a look. Everything looks fine, but when it's on the 'play' position, the black wheel does not connect with the right reel to move it. I'm not sure on how to fix this. If anyone could give me some advice that would be grand. I'm sorry for the poor use of terminology. |
30th Sep 2012, 8:53 pm | #2 |
Re: Grundig TK-121 rewinds, fast forwards but only one reel 'plays'.
Picture here. There are three drive belts, my guess is the one for the take up reel has snapped or gone hard. Open it up and check.
Regards, Ben. |
30th Sep 2012, 9:06 pm | #3 |
Ah, you are right. I had it opened up but I didn't notice. I see one main belt, I guess the drive belt, one that has broken that I have just taken out and one I can't see.
Two questions: 1. Do you know where to buy replacement belts for the UK. 2. Are there instructions for fitting the replacement belts anywhere online? I have seen an eBay seller selling replacement belts + instructions, but is asking a fair whack for three pieces of rubber and a piece of paper. Thank you. |
30th Sep 2012, 9:51 pm | #4 |
His instruction books are comprehensive and invaluable. I dont know about your machine but some of them, if dismantled in a certain way, the mechanism falls apart like a pack of cards and renders the machine useless.
30th Sep 2012, 9:58 pm | #5 |
Ah, you see, I read that and thought it might have been hyperbole to make those lesser in the know, like myself, purchase. In that case, I might purchase the instructions etc. I am just strapped for cash and thought I could do it on a budget!
Thanks for your help. |
30th Sep 2012, 10:45 pm | #6 |
I would echo what Michael says about the aforementioned eBay sellers belt kits. Whilst I have no association with him, I have purchased at least two of his kits in the past and, although having quite a bit of personal electronics/electromechanical experience, have found them invaluable. The "Piece of paper" that you mention is a quality printed and bound repair manual which contains a number of pages containing a wealth of information. Regards Andrew |
30th Sep 2012, 11:00 pm | #7 |
I have bought belt kits from "Big Dave" from time to time.
The fitting instructions are clear as are the helpful tips and pics in the manual. Recommended. Peter W.....Reelguy. No connection with BD. |
1st Oct 2012, 8:33 am | #8 |
Andifall, if you just need the odd belt ie. the take up belt for your machine contact me.
Colin. |
9th Jan 2015, 9:11 am | #9 |
Apologies for resurrecting an old thread but can anyone tell me if "Big Dave" is still around please? I'm looking for replacement belts for a TK121 and the only ones I can see are Ebay are from Germany. I've also looked for a service manual but they all seem to be in German as well.
17th Aug 2015, 11:05 am | #10 |
Hello everyone, sorry for resurrecting an old thread again but I'm hoping you can help me
I have exactly the same problem with my TK 121 and opened up its bottom to find a snapped belt too but I'm just wondering whether there is a way to gain access to where the belt has come from because they all seem to be underneath a metal frame. Thanks very much |
17th Aug 2015, 3:57 pm | #11 |
Whatever you do, DO NOT try to replace belts from the top, they are intended to be replaced via the lower flywheel bearing, which for obvious reasons has to be removed to allow the belt/s to be inserted. I may have a few belts left for this range, will check.
Colin. |
19th Aug 2015, 6:59 pm | #12 |
