Old 14th Aug 2015, 1:10 am   #1
ben
ben's Avatar
Default Philips N4306 (EL3558/3578)
I am trying to revive this late 60s unit. After sorting the mechnics (usual goo, clutch inserts etc) I am trying to repair the amp.
Sound is present, but has terrible clipping and distortion after about position 1 on the volume control. A quick look at the output stage.... I measured no dead shorts across the two output transistors but I found R68/R69 (both 3R3) burned, I believe these are emitter resistors. Replaced them, Changed c43 (220uF) at the same time whilst I was in there. No change. Removed the transistors from heatsink in case there was some tin whisker grounding things out , and tried briefly -no change. Presumably one or maybe both the transistors are faulty, but I haven't yet taken measurements with power on as I need to knock up some kind of jig - access is pretty dire on these.
Now my question is, the schematic has these as AC128, yet this machine has OC78 types. Anyone know if this was a production change or has someone been there and replaced them at some stage? It certainly looks like the latter.
Regards,
Ben.
Last edited by Brian R Pateman; 14th Aug 2015 at 5:54 am. Reason: Hyperlink removed.
ben is offline
Old 14th Aug 2015, 3:32 am   #2
Maarten
Default Re: Philips N4306 (EL3558/3578)
If yours is an early model or from another factory, it could have had those OC78 from the factory. The schematic without service bulletins and version- or countryspecific information is only really representative of one version.
Is there a label on the chassis with a few letters and numbers, such as ZB or WR? The label could also be next to the model label. Is there an execution suffix behind the N4306 model number?
On the other hand, the OC78 my have already been a few years out of production.
Maarten is offline
Old 14th Aug 2015, 11:23 am   #3
ben
ben's Avatar
Thanks Maarten. It's a /15 suffix (bought in UK so I think that's correct) s/n is 021411
Regards,
Ben.
ben is offline
Old 14th Aug 2015, 9:22 pm   #4
TonyDuell
For what it's worth, the service sheet for my Philips AG4000 record player says that the
input transistor can be AC125 or OC75 and that the output pair are either AC128s or OC74s. Replacements should be with the same type. I can't see any R's or C's that depend on the transistor type though.
TonyDuell is offline
Old 15th Aug 2015, 10:02 pm   #5
Jimmyhaflinger
Jimmyhaflinger's Avatar
the N4306 is from late 1967, the OCxx transistors were last made in 1964 or so i think, so i guess they were improperly replaced by someone
BTW i'm also restoring a N4306, the amp works fine in my recorder, so if you need some voltage readings let me know!
Jimmyhaflinger is offline
Old 16th Aug 2015, 1:47 am   #6
Maarten
I think it is likely they were replaced sometime, especially since it is a recorder from the UK and it seems those transistors were last used in equipment from the UK (so probably abundantly available as surplus material).
However one small detail that I'd still like to know... Is there a separate label with two letters indicating the factory, such as WR, AH, ZB?
Maarten is offline
Old 16th Aug 2015, 11:10 pm   #7
Jimmyhaflinger
i have two N4306 recorders, both are WR, while my EL3558 is AH
Old 17th Aug 2015, 3:06 pm   #8
Maarten
Those make sense (Austria and Belgium, with Belgian production maybe already being phased out around the time the N4306 came to market), but I'm wondering whether there ever was production in the UK. I hope Ben gets around to having another look at his recorder.
Maarten is offline
Old 17th Aug 2015, 9:39 pm   #9
Jimmyhaflinger
maybe also the early EL3578s were still made in Belgium?
by the way, while the basic mechanism is the same for both recorders, the brakes were redesigned and are a lot better in the EL3578 and N4306 as they were made from durable fiber pads, while they're made of the usual gooey rubber in the EL3558
Old 7th Sep 2015, 2:16 am   #10
ben
ben's Avatar
Update. Fixed the recorder.
Upon removing the transistors completely and taking them out the heat sink I found one to be an AC128 and the other an OC78 - bit of a bad practice to have unmatched ones in the o/p stage !
The OC78 measured o/c all ways. I suppose one of them might also have shorted to the can.
Replaced with AC188, so far so good.
Now all I need is a speed change knob....
Regards,
Ben.
ben is offline
Old 7th Sep 2015, 2:18 am   #11
ben
ben's Avatar
No sign of any such labels unfortunately Maarten.
Regards,
Ben.
ben is offline
Old 7th Sep 2015, 12:26 pm   #12
ben
ben's Avatar
Correction: Found the label!
WR 02 46 67
Presumably that's 1967 as year of manufacture?
Regards,
Ben.
ben is offline
Old 9th Sep 2015, 3:18 am   #13
Maarten
Week 46 of 1967. WR for the Vienna factory, design revision 02.
I think we can safely say that the OC78 was not a factory original part in any way!
Maarten is offline
Old 10th Sep 2015, 12:12 am   #14
Jimmyhaflinger
the speed change knob from a much more common N4308 fits just fine
Old 10th Sep 2015, 1:09 am   #15
radiotechnician
The Canadian distribution manual shows AC128. It was know as the
'Continental 220' here.
My reference manual is TR2007-8-66.
That model was one of the series I serviced as my firm sold them.
Steve Dow
VE7ASO
radiotechnician is offline
Old 10th Sep 2015, 10:19 pm   #16
Jimmyhaflinger
this recorder, along with all other models based on this mechanism, should always have their speed selector set to the 4,75 position when not in use, otherwise the capstan belt will get stretched if left in the 9,5 position and will slip or fall off the pulley the next time the recorder is used at 4,75
