Old 12th Mar 2020, 9:09 pm   #1
river9999uk
Default ALBANY HOUSE AM-108 Amplifier
Hi
My 2nd repair/restore is a Albany House AM-108 (70s Amp?). This is another junk shop rescue. Oddly its in amazing condition and look unused (have its box also).
Seems manuals/schematics are non existant. One generic one on here from 10 years ago but not sure how accurate it is so asking if anyone might happen to have an official one ?
Seems to power up OK but need to check what the old DIN style connectors pin out is so I can wire up a phono to DIN lead to test it. Do these old DIN connectors have a standard wiring ?
Cheers in advance.
ID:	200798   Click image for larger version
ID:	200799   Click image for larger version
ID:	200800   Click image for larger version
ID:	200801   Click image for larger version
river9999uk is offline
Old 12th Mar 2020, 9:44 pm   #2
river9999uk
Default Re: ALBANY HOUSE AM-108 Amplifier
Cool thanks
Old 12th Mar 2020, 9:49 pm   #3
ajgriff
ajgriff's Avatar
The attachment might help with the DIN wiring question.
Alan
ajgriff is online now
Old 12th Mar 2020, 10:02 pm   #4
Tractorfan
Tractorfan's Avatar
Smile Re: ALBANY HOUSE AM-108 Amplifier
As a spotty youth many moons ago, I had no idea how DIN sockets were wired. So, I poked the holes with a bit of bare wire and noted which ones produced a buzz on which channel.
The ones that didn't buzz were the outputs.
Cheers, Pete.
Tractorfan is offline
Old 12th Mar 2020, 10:24 pm   #5
Ted Kendall
It's a badged Teleton SAQ-206, if memory serves...
Ted Kendall is offline
Old 12th Mar 2020, 10:37 pm   #6
ajgriff
ajgriff's Avatar
The Teleton SAQ-206B looks very similar but not identical. This link has the owner's manual and schematics which might be helpful:
http://www.timstinchcombe.co.uk/index.php?pge=saq206
Alan
Old 12th Mar 2020, 10:49 pm   #7
vidjoman
Albany House I think was a buy now pay later outfit that sold some goods with their own brand name on. I think this is one of them as suggested above as a Teleton. It would probably been much cheaper as a Teleton from a local dealer.
vidjoman is offline
Old 12th Mar 2020, 10:53 pm   #8
river9999uk
Blimey they are very similar aren't they. Thanks for the info!
Old 20th Mar 2020, 8:47 pm   #9
river9999uk
OK after a few bad caps and replacing the faulty TIP31A the amp is back working...however......
The TIP 31A's get VERY HOT very quickly. Now I suddenly noticed that the compatible schematics show 2SD330 not TIP31A's Also a compatible 2SD330 is a TIP41C. Now I must admit to being a bit of a newbie with transistor replacements but could the TIP31A's be incorrect ?
Am I right in thinking the C,B,E specs are the same except it can take more current so a TIP41C would likely be able to deal with the heat/current better but operate the same ?
Old 20th Mar 2020, 10:23 pm   #10
C,B,E layout and package are the same and TIP41C is a beefier device, but I would be surprised if that would make much difference to temperature in this amplifier.
I'd be looking hard at the output stages idle currents. They shouldn't get hot unless the amp is being run really hard if they're OK
Herald1360 is offline
Old 20th Mar 2020, 10:47 pm   #11
river9999uk
I'll check at idle and running. See what the difference is...
