Old 15th Mar 2020, 12:59 pm   #1
Petedox
Petedox's Avatar
Default Bush TV22 Doubler
Hi, I'm into the second week of my restoration, and have what seems to be the usual double whammy of Frame blocking oscillator TX and LOPT overwind o/c (CRT heaters are ok, I'm hoping it's not LE.....). All other wound components check out ok resistance wise.
Thanks for the heads up from Ian and Fernseh for making me aware of these possible failings, and also to Keith for his excellent restoration link.
So at the moment my blocking TX is with Mr Dinning for rewind, and my LOPT has been stripped of tar. Unfortunately after several hours I just cannot find the 'ends' so I am resigned to either finding a new one (no response to my wanted ad so far!), or using a doubler.
I wouldn't class myself as a complete 'purist' when it comes to restorations, but I like to keep the age and look as close as possible to the original, so I've had an idea to replace the overwind with a similarly sized 'donut ring' doubler which slides over the LOPT. The donut itself would probably be the plastic base of a vitamin pot or similar, with components set in silicone compound, please see attachment.
My questions are:
1) Can you see anything wrong with the general concept of this idea?
2) Are the capacitor values of 10nf@3Kv ok?
Any other observations greatfully received! Thanks.
Pete
Petedox is offline   Reply With Quote
Old 15th Mar 2020, 1:08 pm   #2
peter_scott
peter_scott's Avatar
Default Re: Bush TV22 Doubler
https://www.vintage-radio.net/forum/...t=another+TV22
Peter
peter_scott is online now   Reply With Quote
Old 16th Mar 2020, 9:09 pm   #3
Petedox
Petedox's Avatar
Thanks Peter, I'd already read this interesting thread a little while back.
My main point was regarding the mounting and encapsulation of the doubler. Your picture shows the diodes and caps hanging in the breeze! (bringing back fond memories of my days as a TV man). I'm sure you found a more permanent solution!
Pete
Old 16th Mar 2020, 9:59 pm   #4
peter_scott
Hi Pete,
Not the most beautiful solution but I strapped the original tag to the LOPT tube with a tie wrap and ran the diodes and caps up the side. I used 10nF 3kV caps.
Peter
Name:	TV22 doubler (Medium).jpg
Old 18th Mar 2020, 7:19 am   #5
christianschmit
I may have a LOPT ..can you send a picture
christianschmit is offline   Reply With Quote
