Old 5th Mar 2005, 4:17 pm   #1
Ian Paul
Default Advance E2 Signal lead
I just purchased one of these signal generators and all frequency outputs seem really accurate after all these years! I just need to make up a signal lead. Can anyone suggest something that will suffice for most alignment jobs?
Ian Paul is offline
Old 5th Mar 2005, 6:33 pm   #2
Mike Phelan
Mike Phelan's Avatar
Default Re: Advance E2 Signal lead
Originally Posted by Ian Paul
I knocked up a dummy aerial for mine as per the circuit in the manual, which is just the same as the one for my later Advance B4A - the E2 is now on ebay - but this is slightly overkill - a 300pf and 390ohm in series, as Aerodyne Tony suggests in his excellent book is as good as anything. You need a coil to couple to ferrite rods.
E2s are excellent - I checked the calibration on mine last week, and it is virtually spot-on.
HTH
Mike.
Mike Phelan is offline
