Old 16th Mar 2018, 11:44 pm   #1
Michael Maurice
Michael Maurice's Avatar
Default Soft close lid damper for radiograms
Does anyone know how to repair the soft close lid dampers as fitted to 1950's and 1960's radiograms?
Forum Moderator
Michael Maurice is offline
Old 17th Mar 2018, 12:53 am   #2
Nuvistor
Nuvistor's Avatar
Default Re: Soft close lid damper for radiograms
Can't help with repair but there are plenty gas struts on Amazon for kitchen cabinets if you cannot repair the original.
Frank
Nuvistor is offline
Old 17th Mar 2018, 1:26 am   #3
electrogram
I think on ones I've repaired I just put some 3 in 1 oil into the cylinder to mix with the drying out grease and moved the piston back and forth until a good seal was obtained. Then you find the lid takes too long to close but most have a screw on the end of the cylinder which you can adjust to let air out more quickly.
electrogram is offline
