22nd Jul 2006, 11:43 pm | #1 |
Gunge in mains cable
This afternoon, I had to get a piece of equipment out of the lost, something I built myself a few years ago (over25), when I noticed that the mains plug had a sort of green liquid in it.
This had come out of the mains cable. I put another plug on it and it worked fine. Question: Is it safe to use or should I be replaced the cable? I'm loaning it to a customer for a frew weeks. |
22nd Jul 2006, 11:47 pm | #2 |
Re: Gunge in mains cable
Hello Michael,
I've had this happen before, too. I thought water might have got into the cable somehow, but I'm not sure. The whole length of cable was affected, and it had a rather unpleasant smell which I can still remember in spite of it being many years ago. If anyone knows what's happening here, I too would be interested to know. Nick. |
23rd Jul 2006, 12:05 am | #3 |
While we're curious as to what's causing the green slime from outer space I think it would be prudent to change the cable as it's going to a customer who might not be too amused if something went bang or gunged his/her carpet.
23rd Jul 2006, 12:57 am | #4 |
We had this problem in our last house - in the whole of the fixed wiring!
It was diagnosed as a form of verdigris. The only explanation given was down to the age of the PVC cable - something to do with the plasticiser breaking down, and the resultant acidic compound attacking the copper inside It used to ooze out of the sockets, and drip down the lamp pendants......Great around Halloween! Cheers Sean
23rd Jul 2006, 4:12 am | #5 |
That's exactly what it is. The plastic insulation has reacted with the copper wire and you get the green slime. Also, the mains lead itself sometimes gets sticky.
It's very common on some of the stuff I work on. Is it dangerous? I don't think so. But it's royally disgusting. Just change the mains lead and clean up any gunk that has oozed out with something that evaporates quickly....like Ronsonol (the gasoline used for cigarette lighters with wicks). |
23rd Jul 2006, 10:11 am | #6 | |
Nick. |
23rd Jul 2006, 11:35 am | #7 | |
23rd Jul 2006, 5:02 pm | #8 | |
In fact, it sometimes gets bad enough where you see the ooze leaking around the sides of the plug pins. If you see a conventional "screw-on" plug on any appliance here, it's a good chance that the original moulded plug disintegrated and was replaced. I don't save anything. The mains lead getscut out, tossed and replaced. Any screw-on plugs also get replaced by new ones. By then, the rubber housing has gotten brittle over the decades, anyway. |
23rd Jul 2006, 9:28 pm | #9 |
The plastic has produced fumes and corroded the wire.I have had this with the plastic handle of a screwdriver,just oozes a sticky corrorisve substance that seems to attack anything,eventually the handle just dissapeared!
I have aslo seen corrosion in some rubber covered wire. I would be inclined to replace the cable here. |
23rd Jul 2006, 10:24 pm | #10 | |
Administrator
22nd Aug 2006, 6:49 pm | #11 |
I brought a pair of Philips headphones from Argos once, that also leaked greenish gunge when the cable split, and they were only about 2 years old.
