Old 28th Jul 2006, 4:28 pm   #1
Biggles
Default Octal valve bases.
Octal chassis mount relay sockets make cheap alternatives to octal valve bases. The ones I have used are from RS (part number 419 4222). The solder tag ones are available in minimum packs of 3. The tags on the bases are straight and not splayed like a true valve base but can still be used successfully. Has anyone else used these in the past? I can't be certain of the voltage ratings though, as they are plastic, but I believe they should be rated ok at mains voltages.
Biggles
Biggles is offline
Old 28th Jul 2006, 4:30 pm   #2
JoshWard
JoshWard's Avatar
Default Re: Octal valve bases.
I thought RS still stocked valve bases. They still stock valves. Josh.
JoshWard is offline
Old 28th Jul 2006, 4:35 pm   #3
Biggles
You're probably right Josh, the proper valve bases may well be cheaper knowing my reverse logic approach!
Biggles.
Biggles is offline
Old 28th Jul 2006, 5:35 pm   #4
jay_oldstuff
jay_oldstuff's Avatar
I've use'd the maplin's ones beforwe when i was playing about with some amp desighns also built a trf set useing the same, i have four screwed to a peace of wood for such experiments. the ones i have all pins come out to screw terminals which mackes them ideal for experimenting. not particulerly cheep though.
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train
jay_oldstuff is offline
Old 28th Jul 2006, 5:50 pm   #5
Brian R Pateman
Brian R Pateman's Avatar
Biggles
The Omron ones are very good and as Jay points out have screw terminals so ideal for breadboarding. They aren't particularly cheap though!
Brian
Brian R Pateman is offline
Old 29th Jul 2006, 8:15 am   #6
arjoll
arjoll's Avatar
Jaycar do octal valve bases, NZ$6.70 incl GST each which doesn't seem to bad price-wise (works out to about GBP2.20).
arjoll is offline
