16th Mar 2018, 11:44 pm | #1 |
Soft close lid damper for radiograms
Does anyone know how to repair the soft close lid dampers as fitted to 1950's and 1960's radiograms?
17th Mar 2018, 12:53 am | #2 |
Re: Soft close lid damper for radiograms
Can't help with repair but there are plenty gas struts on Amazon for kitchen cabinets if you cannot repair the original.
Frank |
17th Mar 2018, 1:26 am | #3 |
I think on ones I've repaired I just put some 3 in 1 oil into the cylinder to mix with the drying out grease and moved the piston back and forth until a good seal was obtained. Then you find the lid takes too long to close but most have a screw on the end of the cylinder which you can adjust to let air out more quickly.
