Old 21st Apr 2018, 11:14 am   #41
Martin Bush
Martin Bush's Avatar
Default Re: Bush TP79 cassette
I used to have a Sony pro Walkman but sold it long ago. We also used to use Marantz machines at college which were very good as I recall.
I see you can still get new 'shoebox' players.
Is it live, or is it... no, it's live actually...
Martin Bush is offline
Old 21st Apr 2018, 4:50 pm   #42
TonyDuell
Uher made some small cassette recorders (larger than than a Walkman, but much less than 17" wide) that were good quality both in terms of the audio reproduction and the build.
I have a CR210 (not for sale!) which is stereo and has auto-reverse in play mode.
Be warned that they can be tricky to work on, there is a lot packed into a small box, but they are worth it
TonyDuell is online now
Old 30th Apr 2018, 2:12 pm   #43
Martin Bush
I now have the required socket to make up a power lead. Before I go ahead I wanted to check something.
On opening up the socket (or is it a plug? - you know what I mean anyway, the bit that goes into the tape machine) it looks to me as though the mains cables are to be soldered in place.
Is that correct? I was expecting some sort of arrangement similar to a mains plug with screwed terminals.
Old 30th Apr 2018, 2:29 pm   #44
camtechman
camtechman's Avatar
They are the solder type. There wouldn't be enough room for screw terminals.
The part you have there is this description: Cable ended 2 pin socket, whereas the part already fitted in the machine is designated: Chassis mounted 2 pin plug with switch.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 30th Apr 2018, 3:56 pm   #45
Martin Bush
Thanks. As you say, it does look a bit tight in there.
