Old 26th Nov 2023, 5:24 pm   #1
Pamphonica
Pamphonica's Avatar
Default Trend Data Tester 105
I just got one of these very cheaply in an auction.
It's a fairly chunky serial data tester (4 stacked pcbs inside!) with keypad, display and a useful breakout and patch area based on DB25 connectors.
I would like to use it to check serial data to and from some vintage plotters.
It powers up, now I have removed the very sick NiCd battery pack, which I will re-build.
But I have no idea how to trigger the inbuilt automatic test sequences. I get stuck on messages like "warning. Clears Edit Store", when I try to change "Test Data". I did get QBF (Quick brown fox) displaying as test data for a bit but cannot get back to it. I can display received data from a terminal, so that is progress!
Does anyone remember using these (probably in the 80s) and can help work out how to get the auto test functions? A manual would be nice but there are none online.
any help gratefully received.
-Jeremy
ID:	288817   Click image for larger version
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is offline
Old 26th Nov 2023, 8:58 pm   #2
chriswood1900
Default Re: Trend Data Tester 105
I found this on EEVBLOG hopefully it will be useful.
I could not get a link to the original file to work so reposted here to make it easier.
File Type: pdf Trend Data Tester 105 Operating Instructions.pdf (1.77 MB, 23 views)
Chris Wood
BVWS Member
chriswood1900 is offline
Old 27th Nov 2023, 11:34 am   #3
Pamphonica
Pamphonica's Avatar
Excellent, thank you Chris. I will cross reference your post on the other thread in Vintage Computing.
I think that the main discussion can now go on in Vintage Computing so mods, this thread can be closed - thanks all!
https://www.vintage-radio.net/forum/...d.php?t=205837
-Jeremy
