Reply
Old 23rd Nov 2023, 10:43 am   #1
Electronpusher0
Default Trying to run PLJ's MHSVT card program, Explorer keeps opening in EDGE
I have started a new thread as a breakout from this post
https://www.vintage-radio.net/forum/...2&postcount=13
I tried to run PLJ's program but even though I right clicked and selected open in Explorer it open EDGE instead, and not the file I wanted open, just the normal front screen of Edge.
Does anyone know how to force Windows to open a file in Explorer?
Peter
Electronpusher0 is offline   Reply With Quote
Old 23rd Nov 2023, 10:47 am   #2
Station X
Station X's Avatar
Default Re: Trying to run PLJ's MHSVT card program, Explorer keeps opening in EDGE
Reload in Internet Explorer mode ?
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 24th Nov 2023, 9:07 am   #3
Electronpusher0
Thanks Graham,
excuse my ignorance in this, I do not use Edge.
How to I Reload in Explorer mode?
Also reading on the web I may have to change a setting to enable it to read local files, again I have no idea how to do this.
Any help would be appreciated.
Peter
Old 24th Nov 2023, 9:10 am   #4
Station X
Station X's Avatar
You said that the programme opened in Edge even though you didn't want it to. What I described was how to switch from Edge to Internet Explorer.
Old 27th Nov 2023, 11:55 pm   #5
Graham G3ZVT
Graham G3ZVT's Avatar
Are you trying to download the .zip file I have attached to this post?
It may well open Edge when you double click it, but if you look in your downloads folder, you should find the file and you can extract the files there.
Graham.
G3ZVT
Graham G3ZVT is offline   Reply With Quote
Old 29th Nov 2023, 8:33 am   #6
Electronpusher0
To be clear what I am trying to do.
I have extracted the zip file Graham has posted above into a separate folder.
I then right click the file MHSVTcalculator.html and select "open with", I select Microsoft Explorer and Edge opens, on the front screen, no sign of the MHSVTcalculator.html file.
I have changed the windows file preferences to specify that MHSVTcalculator.html should always open in explorer but still no luck.
I do understand that you suggest switching to explorer once Edge opens Graham (station X) but I have no idea how to do that, sorry.
Peter
Old 29th Nov 2023, 8:45 am   #7
Station X
Station X's Avatar
Click on the three dots at the top right of the MS Edge screen, Then select "Reload in Internet Explorer Mode" from the drop down menu as per the screen shot in post #4.
Old 29th Nov 2023, 8:49 am   #8
Electronpusher0
Peter
Old 29th Nov 2023, 8:56 am   #9
Electronpusher0
OK thanks Graham,
I have tried following your instructions but open in Explorer is greyed out in the drop down menu
see screen shot.
Peter
Name:	Screenshot 2023-11-29 075554.jpg
Old 29th Nov 2023, 9:07 am   #10
Electronpusher0
OK, turns out it was in Explorer mode, thats why it was greyed out.
I can now open the file by using ctrl O.
The program now opens.
BUT, no matter what card No I enter nothing happens.
EDIT, OK I am officially an idiot, I missed the pop up right at the bottom of the screen inviting me to allow blocked content.
Peter
Reply
