27th May 2020, 5:34 pm | #1 |
Pye PE98U SW problem
I'm working on a Pye PE98U and have encountered a very odd problem.
On LW and MW bands it works a treat. On SW it only works on frequencies above about 12 Mc/s. The local oscillator output diminishes gradually as the gang is meshed and ceases entirely at rather less than half mesh. I've cleaned the wavechange switch which has made a slight improvement, and changed the UCH42 which made no difference at all, so I'm seriously puzzled. Relevant bit of the circuit diagram attached. |
27th May 2020, 5:44 pm | #2 |
Re: SW problem
Hi.
Assuming the frequency changer valve is OK and the DC readings up to scratch, there's a strong possibility that the relevant osc coil has gone low-Q due to either damp or some degradation of the wax impregnation. I'm not sure if that model uses wax impregnated coils, but if it does it's a possibility. The other possibility is slightly leaky caps, especially the low-value ones in the anode and grid circuits of the oscillator. Some of these oscillators were a bit marginal at the extreme low or high end and it didn't take much to stop them!
Andy G1HBE. |
27th May 2020, 9:25 pm | #3 |
Re: Pye PE98U SW problem
C14, C17 & C20 are probably silver mica and so are unlikely to be leaky. Although often wax coated if the coating has breaks or damage at the edges it can allow moisture in and oxidise the silver foils which does occasionally affect capacitance. This can be enough to affect oscillator performance. Worth checking the values. Also, assuming L5 is the SW osc coil, check C13 as well. Oh, and check the voltages on the UCH42 compared to the Service data (R5 might have gone high). Cheers, Jerry
