12th Oct 2014, 7:25 am | #1 |
HMV 2002 volume problems
I have a recent problem with my record player.
The make and model is HMV 2002. The volume is nice and loud when it first warms up, but then after a few more minutes the volume fades and the only way to hear the music is to turn the volume DOWN. Was wondering if this needs the valves replaced? I doubt it to be the cartridge as it is only a couple of years old. |
12th Oct 2014, 12:37 pm | #2 |
Re: HMV 2002 volume problems
If the sound fades after a couple of minutes, I would have thought you'd need to turn the volume control up not down. The Cartridge may only be a couple of years old, but the player is far older. The problem is unlikely to be the tubes (valves). With exceptions, they seldom fail. It's more likely to be due to faulty capacitors, especially waxed paper types, which, if not replaced can cause serious trouble, such as damage to the output valve, output transformer, and even to the mains transformer (if one is present) due to excess current being drawn
12th Oct 2014, 3:20 pm | #3 |
I would agree. The coupling capacitor to the grid of the output valve is probably leaky upsetting the bias and causing the valve to overheat.
Peter |
12th Oct 2014, 3:55 pm | #4 |
It won't be the coupling cap- there isn't one. It's a single UL84 amp job. It might be screen or cathode decouplers going down or just a tired rectifier.
I suspect some voltage readings when cold and warm for the UL84 would be informative if ZZ is familiar with safety when working on live chassis equipment.
13th Oct 2014, 3:45 am | #5 |
And nothing happens when I turn the volume up. There is no sound. If I turn the volume down eventually I do get sound coming from the speakers.
Thanks for the input guys. I think I'll have a professional look at it. |
13th Oct 2014, 11:46 am | #6 |
Pardon my ignorance.
Peter |
