Old 6th Dec 2017, 1:37 pm   #1
SurreyNick
Default Cog for Ormond Slow Motion Dial
I am in need of a small cog for an Ormond Slow Motion Dial.
It is missing one of its original cogs and the replacement which is made of plastic (see pic) doesn't work properly. I don't have the tools to fabricate a replacement and it would be a shame to throw the dial away for the sake of a cog.
Does anyone have one in a box of loose parts?
I'm happy to pay.
Thanks
Nick.
Name:	Ormond Slow Motion Dial cogs.JPG
ID:	153472   Click image for larger version
Name:	Ormond Slow Motion Dial.JPG
SurreyNick is offline   Reply With Quote
Old 6th Dec 2017, 4:56 pm   #2
Ed_Dinning
Default Re: Cog for Ormond Slow Motion Dial
Hi Nick, if all else fails I believe there are some clockmakers in your locality, they should be able to make one up pretty easily out of brass sheet.
Ed
Old 6th Dec 2017, 7:56 pm   #3
Goldieoldie
Hi
You could try a tight fitting rubber gromet
Cheers Pete
Goldieoldie is offline   Reply With Quote
Old 6th Dec 2017, 9:41 pm   #4
camtechman
camtechman's Avatar
Pete, soon grommets will be in demand !
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline   Reply With Quote
Old 6th Dec 2017, 10:18 pm   #5
Goldieoldie
Must get Wallace on board !
Old 6th Dec 2017, 10:20 pm   #6
camtechman
camtechman's Avatar
Boom! Boom!
Old 7th Dec 2017, 10:36 am   #7
My experience of slow motion drives says that that's a simple grooved pulley rather than a "cog" with teeth.
Given an accurate drawing I could make one for you. The only tricky bit could be the cutting of the groove if it's very narrow.
Keep the soldering iron hot.
Old 7th Dec 2017, 1:22 pm   #8
SurreyNick
That is very kind of you Graham and I would love to take you up on the offer.
You are quite right, it is a grooved pulley and not a cog and if it will help I can send you the remaining one to copy. I will of course pay you for your time, trouble and materials etc.
Thank you
Nick
Old 7th Dec 2017, 1:34 pm   #9
I'll PM you.
Old 8th Dec 2017, 2:11 pm   #10
60 oldjohn
Hi Graham, I have taken some photos of the wheel needed, might help, and the 1.5mm hole has a slight chamfer on one side only so it don't bind on the wire support. Yes there is an Ormond slo mo version that has teeth, this is the toothless version. I don't believe the measurements are critical to 0.01mm as shown as it is spring loaded.
John.
Name:	ormond slo mo 005.jpg
ID:	153618   Click image for larger version
Name:	ormond slo mo 007.jpg
ID:	153619   Click image for larger version
Name:	ormond slo mo 008.jpg
ID:	153620   Click image for larger version
Name:	ormond slo mo 006.jpg
60 oldjohn is offline   Reply With Quote
Old 8th Dec 2017, 2:15 pm   #11
Thanks John.
Nick is sending me an original pulley as a pattern.
I can see that some tool grinding will be needed to cut the groove.
Old 8th Dec 2017, 2:22 pm   #12
60 oldjohn
Originally Posted by Station X View Post
Thanks John.
The last one I made I just used a junior hacksaw blade. Looking at my photo close up it appears to be flat in the bottom of groove. The wheels in my photos are originals.
John.
Old 8th Dec 2017, 2:53 pm   #13
I think the groove needs to be vee shaped, as the big disc contacts the sides of the groove rather than the bottom to give increased contact pressure.
I'll grind a bit of power hacksaw blade, or possibly a 1/16" wide parting tool blade. My late father left me his lathe tool grinder where you can set a multitude of angles, but Ill do this by hand.
Old 11th Dec 2017, 3:44 pm   #14
I received the pulley from Nick today. First thing I did was to thread it on a loop of wire so I don't lose it!
It has a parallel sided flat bottomed groove which will make things easier. I notice that there's a black sticky substance in the bottom of the groove. Is this the remains of an 'O' Ring or just accumulated grease and dirt?
Old 11th Dec 2017, 6:17 pm   #15
60 oldjohn
My guess is years of dirt, all mine are clean. I did no cleaning before taking photo.
John.
Old 12th Dec 2017, 8:24 pm   #16
SurreyNick
It is old grease deposits. The dial innards had been smothered in the stuff, much of which was almost wax-like from age/impregnated dust etc. it would seem the degreasing solution didn't quite complete the task. Sorry I missed it Graham, the eyesight isn't quite what it used to be.
Nick
Old 15th Dec 2017, 3:02 pm   #17
The original pulley and two new ones are now on their way to Nick.
Fiddly little things, but I managed not to lose any.
Old 15th Dec 2017, 8:27 pm   #18
stevehertz
stevehertz's Avatar
Nick, out of interest, is the dial part of a bigger project or just for restoration?
stevehertz is offline   Reply With Quote
Old 17th Dec 2017, 11:44 am   #19
SurreyNick
A couple of years ago I picked up a partially complete cabinet belonging to an original 1927 Cossor Melody Maker and since then I have been collecting exact original components (those specified in the construction broadsheet) with the intention of re-constructing it. With a bit of luck it will one day re-surface complete and working
Are you after one? I ask because I do have a few other slow motion dials, including a lovely matching pair of Polar Slow Mos
Nick
Old 18th Dec 2017, 11:05 am   #20
SurreyNick
This morning, through the post, I received a set of expertly fabricated pulley wheels for my Ormond Dial. Reassembled the dial now works perfectly again.
Thank you Graham, you're a real Gent.
The spare wheel is in my store of little parts. If anyone ever needs it to repair a dial of theirs just ping me a message and it's yours.
Nick.
Name:	Ormond Pully Wheels 01.jpg
ID:	154156   Click image for larger version
Name:	Ormond Pully Wheels 02.jpg
