3rd Mar 2013, 7:44 pm | #1 |
Ekco DC 15/25 Battery eliminator.
Hi folks.
Searching in the loft I rediscover this Ekco battery eliminator purchased some time ago. Looking at the at the selector panel I can see H and L for screen grid, Neg, and two other outputs, one 50/80, the other 120/150. Then there is a selector giving and H, M and L option, I presume high, medium and low variations on 50/80 or 120/150. No suggestion of any filament voltages. How would a sets filaments be powered when using this? I see no device to rectify ac, so I guess the model number, DC 15/25 indicates it was for DC mains only. Any ideas of how it could be adapted for modern safe mains use? As you can see, there is what looks like an encapsulated capacitor block that is all bulged up, so I think that will need attention. I have a Burndept CN240 battery set and originally acquired this eliminator in the hope I could power the Burndept.
The older I get, the faster I was! |
4th Mar 2013, 10:02 pm | #2 |
Re: Ekco DC 15/25 Battery eliminator.
As you rightly surmised, this was for DC mains. It is an HT eliminator only, no provision for LT. They were usually simple resistor droppers, so the voltages would be dependant on the current draw of the receiver (15-25mA perhaps?).
It would need a mains transformer adding to be useful, and new smoothing capacitors. |
5th Mar 2013, 7:28 pm | #3 |
Hi Bill, I originally bought this with the idea I would use the case and fit a transformer etc, with a zener regulated selection of HT outputs, but I find myself in that difficult position of destroying all the units originality. I may eventually modify it, after all it's no use as it stands. And of course I could add an LT section at the same time.
Andy
5th Mar 2013, 9:10 pm | #4 |
Kept original it makes a good door stop.
As there is little of use in it, a sympathetically constructed power supply would keep the vintage look and be safe into the bargain. |
5th Mar 2013, 9:40 pm | #5 |
Hi Andy, this is very similar to the AC versions of the eliminators but with a dropper not a transformer. Ditch the dropper and fit a transformer, re-stuff the cap can and use an Si bridge; you have the AC version. There is probably also space to fit an LT supply with a chip regulator as well. Transformers from old VCRs often have a range of windings that will suit.
Ed |
