21st May 2017, 3:57 pm | #41 |
Re: ITT CVC9 Frame fault
Ok I shall have a look.
Many Thanks Jan |
21st May 2017, 8:37 pm | #42 |
You say it's a disc. What colour is it, and the stripes if any. The Mullard data is a bit sparse to say the least.
21st May 2017, 8:56 pm | #43 |
The Mullard data in that book for that type (E299DD/P344) shows it has a code number of 2322-552-03441, that number is listed with the following band colours starting at the top of the VDR, 1) Orange, 2) Yellow, 3) Yellow.
Lawrence. |
21st May 2017, 9:12 pm | #44 |
I wonder if a 110 or 120 volt zener would do to replace the VDR?
Lawrence. |
21st May 2017, 9:18 pm | #45 |
As a test I would use a resistor, need to work out a value to give 4 or 5ma no more than 10ma through the OA91.
If it was me I would defeat the sound muting, check that the g1's on the CRT are biased approx correct and concentrate on the other problems first. Frank |
21st May 2017, 9:25 pm | #46 |
4 or 5mA? I don't follow?
Lawrence. |
21st May 2017, 9:31 pm | #47 |
Enough to put the OA91 into conduction to defeat the sound mute without overloading the diode and burning it out.
Perhaps I am thinking about it incorrectly but that's my thoughts. Frank |
21st May 2017, 9:39 pm | #48 |
I think the max zener current would work out to be less than 2mA so far as I can make out.
Lawrence. |
21st May 2017, 9:49 pm | #49 |
Hi.
Do you have a photo of the VDR Jan? I have quite a few pulled VDRs from various sets so may be able to help. I can't at present check my CVC9 for the type of VDR as it's not immediately accessible. Regards Symon. |
21st May 2017, 10:13 pm | #50 | |
I looked at the OA91 spec and 4 mA gave about 0.4v drop across it so 2mA may be enough if you used a zener to replace the VDR. Hope I am following this ok, apologies if I am not. Frank |
21st May 2017, 11:41 pm | #51 |
I have a few pulls too, but not orange/yellow/yellow. From mine it would appear that it may look like a narrow orange with a broad yellow.
22nd May 2017, 7:55 am | #52 |
30th May 2017, 11:01 am | #53 |
Hi there Everyone! Thanks for all the very useful replies.
Ever so sorry for the long reply. its been a hectic last week or so. Heres a picture of the VDR. Theres no colours on it at all. just a pale sandy colour body. (not the best quality image. ive not got a macro lense) I have also replaced R422 1.8k and C306 330pf on the lopt panel which were bad. Still no change. Kind regards, Jan |
8th Jun 2017, 11:28 pm | #54 |
Hi
I now have a picture! A bad connection on the frame output transformer was causing the problem. Alo a fuse had opened on the power supply panel. The tube looks good, very weak/wrong colours and lack of control of brightness to look into. also the issue of no sound. Regards, Jan |
10th Jun 2017, 10:43 am | #55 |
Hi Everyone.
The CVC9 Is finally up and running perfect! The lack of audio was traced to an O/C 3.3k resistor in the audio output stage. Replacement gave me fantastic clear sound. The wrong/lack of colours turned out to be a faulty TDA1327A on the Decoder. It looks like whovever owned the set previously had twiddled every pot in the convergence box and screwed everything up. a quick and dirty greyscale and convergence set up gives very pleasing relults. The tube is a cracker!! The cabinet has also been re-finished with some suitable similar colour fablon as the cabinet was very rough round the edges. Many thanks to all those who helped me get it going Regards, Jan |
10th Jun 2017, 11:05 am | #56 |
That looks great and you have an impressive set up there, i spy PS1 and PS2 under the tv
very nice |
10th Jun 2017, 12:49 pm | #57 |
Very nice pics there jan. also am I right in thinking that the skantic and the bush portable were the sets I took to mikes in may?.
Cheers Neil. |
10th Jun 2017, 2:29 pm | #58 |
Hi Neil. Yes they are indeed. Both Working quite well. Many thanks.
And thanks Records. I "chipped" the ps1 so I didn't have to spend ludicrous amount of money on games lol. Regards. Jan |
12th Jun 2017, 10:56 am | #59 |
That looks good! Quite an unusual and attractive woodgrain finish on the front of the TV, quite unlike the two I have here.
As usual a great picture on one if these - they just go on and on. Glyn |
