Old 25th Jun 2021, 9:26 am   #1
Dick Glennon
Default Stylus for PYE Play Boy record player.
Hi, I want help with getting a Stylus for a PYE playboy record player. It was purchased in 1965 in Ireland. It has a BSR deck if that is of help. Would I need more information or a part number so I could order same . Any help would be very much appreciated. Regards, Dick.
Dick Glennon is offline   Reply With Quote
Old 25th Jun 2021, 10:34 am   #2
Edward Huggins
Default Re: Stylus for PYE Play Boy record player.
We can't suggest a correct stylus until we know what type of cartridge is fitted - is there a name or number on it?
Edward.
Edward Huggins is offline   Reply With Quote
Old 25th Jun 2021, 11:00 am   #3
hayerjoe
hayerjoe's Avatar
Any chance of a picture of the Pye Playboy? I've never seen one. Long legs I bet!
hayerjoe is offline   Reply With Quote
Old 25th Jun 2021, 2:14 pm   #4
Edward Huggins
No, there are no long legs - I should know, I designed!
We need to know the type of cartridge now fitted to advise as to the stylus.
Edward.
Old 25th Jun 2021, 7:58 pm   #5
Dick Glennon
Hi Edward, This is my first record player to try and replace a stylus. I do not have it in my posession at present but will have it in the next few weeks so I will examine it in more detail. Thanks for replies so far, Dick.
Old 25th Jun 2021, 8:16 pm   #6
Nickthedentist
Nickthedentist's Avatar
More info here: https://www.vintage-radio.net/forum/...d.php?t=141834
The original cartridges were either BSR TC8M or a UTM ElectroVoice PowerPoint (whose stylus could not be replaced), but as our Pye expert says, it could have been changed for something else many moons ago.
Old 28th Jun 2021, 6:43 am   #7
hayerjoe
hayerjoe's Avatar
That's great, so you worked for Pye? Also did you design the electrics/chassis or the exterior or everything?
Old 28th Jun 2021, 8:16 am   #8
Edward Huggins
I designed the cabinet and specified the coverings, fittings and acoustic porting.
This then determined the chassis size and the maximum sized speaker for it.
Edward.
Old 6th Sep 2021, 8:36 pm   #9
Dick Glennon
hi again, The record player eventually got to me. It has a bsr c 1 catridge fitted. It seems as if someone had tried playing it with no stylus, so I may have to get the catridge and stylus complete.Is there any such thing available any more, any help would be most welcome. Regards, Dick
Old 6th Sep 2021, 10:17 pm   #10
Techman
Techman's Avatar
I would check your original cartridge first, as it's a stereo compatible ceramic type.
A Chinese ceramic would replace it, but then you'll have to check and possibly alter the tracking weight.
Post a clear picture of what you've got.
Techman is offline   Reply With Quote
Old 6th Sep 2021, 11:50 pm   #11
ben
ben's Avatar
The BSR C1 originally came with ST3 or ST4 stylus. These have two tips, one for playing vinyl LPs and 45s and another for 78s/gramophone records.
You can also use ST12, ST14 (as above, if you have 78s/gramophone records).
If you dcon't plan on playing 78s, then best value is the ST15 (two vinyl tips, so when one wears out you can flip the stylus over to the other tip).
Ben.
Old 7th Sep 2021, 5:58 am   #12
Edward Huggins
The Playboy used two amps over its life. The first was a basic EL84 type, then 2 years later came an ECL82 version. The (non-original) BSR C1 cartridge will only work well with the latter. The build quality of these amplifiers would put any Dansette amp to shame!
Edward.
Old 8th Oct 2021, 2:20 pm   #13
Dick Glennon
Hi again, I have an st 10 stylus, would this work in the c1 cartridge. Regards, Dick.
Old 8th Oct 2021, 4:17 pm   #14
Edward Huggins
The BSR ST10 is a low compliance stylus. Don't use it on your best Stereo records. Fine for most Mono records.
Edward.
Old 8th Oct 2021, 4:39 pm   #15
Ekcoman
Ekcoman's Avatar
Great little record player and if I remember did very well in a WHICH report back in the early 60s. Still have one and the 2nd version?
Name:	PYE 1002 (Playboy Compact) b.jpg
ID:	242951   Click image for larger version
Name:	PYE 1002 (Playboy Compact) a (1963).jpg
"I really am seriously downsizing "
Ekcoman is offline   Reply With Quote
Old 9th Oct 2021, 6:26 am   #16
Edward Huggins
Good to see this again as it looks to be in excellent condition and with no serious dents in that metal mesh grille. It was a good idea to specify this type of grille as it had excellent acoustic transperency and certainly looked classy, but was terribly prone to getting damaged. Yours should have the superior ECL82 amplifier from 1963.
Edward.
Old 9th Oct 2021, 8:58 pm   #17
Ekcoman
Ekcoman's Avatar
I have the original instructions somewhere. As soon as I locate will put photos up.
Old 10th Oct 2021, 10:16 am   #18
hayerjoe
hayerjoe's Avatar
Nice to finally see a good picture of the "Playboy", looks like a quality unit. I really like the deck, looks like a cream and grey UA15 (a great colour combination ive not seem before). FYI the UA15 was designed by famous industrial designer Raymond Loewy (Coke bottle, Shell logo, Concorde interiors etc see photo) and was quite a design leap from the 50s looking UA14
Name:	BSR 1962 369.jpg
Old 10th Oct 2021, 10:25 am   #19
Nuvistor
Nuvistor's Avatar
Always likes the look of the UA15/16 compared to earlier versions, the metallic blue took my eye.
Frank
Nuvistor is offline   Reply With Quote
Old 10th Oct 2021, 10:52 am   #20
hayerjoe
hayerjoe's Avatar
so is that metallic blue in the photo? very nice
question for Edward (designer of the Playboy): how much flexibility did you have ordering different coloured decks from BSR?
