3rd Mar 2023, 2:36 pm | #1 |
Level selective amplifier circuit needed
Dear all,
I wonder if a level selective HF amplifier circuit exists out there. An amplifier that amplifies more the high level signals above a settable threshold and less (if not at all) the low level ones. This is not the same as a squelch circuit, but rather exponential level amplification. Any help towards this direction, would be much appreciated. Thank you |
3rd Mar 2023, 6:57 pm | #2 |
Re: Level selective amplifier circuit needed
I thought thats what graphic equalisers were designed to do having several frequency set ranges, perhaps I misunderstood the question.
Dave
3rd Mar 2023, 8:48 pm | #3 |
No, it's not a graphic equaliser, it's actually an expander, AGC achieving the opposite effect - increasing the variation in input signal level.
I can't think of a use for one. David
3rd Mar 2023, 9:15 pm | #4 |
You would need a level detector driving a comparator and some switching, or maybe something more elegant.
Are you asking for an expander/noise gate? What is your intended use?
"Behind every crowd, there's a silver Moonshine" Last edited by Cruisin Marine; 3rd Mar 2023 at 9:24 pm. |
4th Mar 2023, 9:14 am | #5 |
An OpAmp with a PN junction in the feedback path has a transfer function which is either logarithmic or exponential depending on where you place the diode. This was used a lot in the days of analogue computing, it has the disadvantage of poor temperature stability in its simplest form. Is that anywhere near what you need?
Roger |
