16th Feb 2023, 8:03 pm | #1 |
Confirm capacitor polarity
I'm recapping a Hallicrafters SX-62 and wanted to confirm polarity on one of the capacitors. The parts list says it is electrolytic (10uF 25v) but the schematic does not indicate polarity. There is a little + on the capacitor, but I wanted to confirm the + was for the right side being positive (in the photo).
16th Feb 2023, 8:10 pm | #2 |
Re: Confirm capacitor polarity
I should have included it is C107 in the schematic.
16th Feb 2023, 8:15 pm | #3 |
It looks so. The end to pin 3 on the valve socket will be the positive end.
You have a fair crop of wax/paper capacitors about too, and carbon resistors are worth a stab with the ohmmeter. The big one in the middle looks to have sweated a bit. David
16th Feb 2023, 8:29 pm | #4 |
The photograph does not appear to match the part of the schematic you have selected.
I would expect the positive side of a 'cathode bypass' electrolytic capacitor to be connected to the cathode. The cathode would be on pin 3 of the 6SL7 valve holder. The photograph appears to highlight a waxed paper capacitor. |
16th Feb 2023, 8:38 pm | #5 |
You are right. The capacitor of interest is connected to pin 6 of the valve socket. Let me go back to the schematic. Stay tuned.
16th Feb 2023, 9:03 pm | #6 |
The socket the capacitor was soldered to in the photo on the left is V13 (6V6GT). On the bottom of the socket, it was soldered to pin 6 (based on the imprinted label). It looks like pin 6 was just used as a soldering terminal with no connection to the valve.
So, what I think is the positive side of the cap, connects to a terminal on the right that has a jumper-wire to pin 3 of the V-11 (6SL7) valve. Sorry for the confusion. So pin 3 would be the positive side of C107? |
16th Feb 2023, 9:17 pm | #7 |
Ref. the previous post, folks can see the wiring here, the 6SL7 valve holder being the bottom right one in the group of four:
https://vintagetubeelectronics.com/w...SX-62A-003.jpg Lawrence. |
16th Feb 2023, 9:23 pm | #8 |
Thanks for that reference. That is opposite of what I thought. Negative side of the cap connects to pin 3 via the jumper wire.
16th Feb 2023, 9:23 pm | #9 | |
https://en.wikipedia.org/wiki/Cathode_bias Make sure you check the waxed paper capacitors as Radio Wrangler says. They're most likely to be leaky, and rather more of a problem than a cathode bypass capacitor. |
16th Feb 2023, 9:39 pm | #10 |
Thanks! And yes, I'm replacing about 50 capacitors (a kit from HayseedHamfest).
