12th Feb 2023, 7:39 pm | #21 |
Re: Misbehaving power transformer
Rewinding with Brocotts finest...
13th Feb 2023, 9:16 am | #22 |
That's excellent winding for a hand wind with a drill.
Andy.
13th Feb 2023, 9:22 am | #23 |
Seconded!
13th Feb 2023, 10:27 am | #24 | |
I cut off the original 10mm threaded bar and welded on the chuck adaptor. I took my time with the primary wind in layers as it's a bit easier due to the 0.45mm diameter wire. A couple of 70's Genesis albums and a few breaks for tea and biscuits, a perfect way to spend a Sunday afternoon. The secondary at 0.3mm is random wound though. For the random wind I attach an 18v drill in place of the winder handle to get a nice consistent rate. Doug |
13th Feb 2023, 10:46 am | #25 |
I did that too... they're really crummy-looking winders, appalling casting quality - but they do their job. (Mine, I had a local machine shop to thread the shaft to fit the chuck).
Greasing the gears and a drop of oil on the plain bearings helps a lot, but crank the handle briskly afterwards with a cloth to catch surplus flying grease! |
13th Feb 2023, 10:57 am | #26 | |
Next mod planned is to attach an old 12v NiMH drill motor and chuck (NiMH cells long dead) and use the drill handle speed control in a foot controller for hands free operation. |
13th Feb 2023, 7:41 pm | #27 |
All rewound and reassembled now.
I added some more options. HT is now 150v-140-130-120-110-CT-110-120-130-140-150v Bias supply is 20v-CT-20v 2 x 6.3v @ 1.3A for filaments 10.5v @ 0.65A for DC filament supply No load draw on primary is 110mA, bulb limiter stays dull. Will add some load and check temps next. Completed primary and reassembled laminations pics attached, will add bolts. |
