Old 17th Jan 2023, 12:58 pm   #1
Superscope
Default Li-ion 17670
Does anybody know where I can buy 17670 Li-ion Cells?
Plenty of compatible chargers out there, but the Cells seem illusive.
Ian
Superscope is offline
Old 17th Jan 2023, 1:27 pm   #2
GMB
GMB's Avatar
Default Re: Li-ion 17670
Remember that "Li-ion" is not a single thing, so you need to decide which kind you want.
GMB is offline
Old 17th Jan 2023, 2:17 pm   #3
Superscope
Well, I can't say what the exact Chemistry is, as even the Data sheet doesn't say,
but it won't be anything Modern and exotic like Li-poly ect.
The Cells I need to replace, are from a 1999-2000 Toshiba Laptop and have a
nominal voltage of 3.6-3.7. with Max charge voltage of 4.2, so pretty standard stuff for
old school cylindrical cells.
I would guess they are LiCoO2 which fits in with these being Sony Branded Cells of
that period.
Ian
Old 18th Jan 2023, 2:20 pm   #4
Andrew B
Andrew B's Avatar
Deft work and "garden type" 18650?
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 18th Jan 2023, 2:38 pm   #5
paulsherwin
paulsherwin's Avatar
17670 is an unusual size which I've never come across. Almost all laptops use battery packs built around 18650s.
paulsherwin is online now
Old 20th Jan 2023, 12:46 pm   #6
Superscope
Sadly, that is not an option here, it's a pretty tight fit even with 17670's.
I guess these must have been common in the past.
A quick Ebay search brings up dozens of compatible chargers without it seems any
reference to the 17670 Batteries themselves.
I think I have found a solution though, in the form of 16650's which are still available.
So a fraction smaller theoretically (which is handy) and actually 2000mAh instead of
the original 1500mAh.
Batteries are ordered, so will see how this works out.
Ian
ID:	271851   Click image for larger version
ID:	271852   Click image for larger version
Old 15th Feb 2023, 12:07 pm   #7
Superscope
And indeed it worked out pretty well.
Still a bit fiddly even with 16650's, so even if I had found the original 17670's
it would have been a very tight squeeze and probably would have ended up
bulging the plastic Battery Case somewhat.
So, original Battery Pack was 1500 mAh, and the new Cells are 2000 mAh,
so a 33% increase in capacity, give or take.
On the first test, the little Laptop ( Toshiba Libretto ff1100 ) ran for about
2 hours playing music on it's very small speaker.
This Laptop is Tiny.
Floppy Disk shown for scale.
Ian
ID:	273312   Click image for larger version
