Old 28th Sep 2005, 11:23 am   #1
tvden
tvden's Avatar
Default PYE LV 30 RF section
Hi all I have just started work on a Pye LV 30 and the first thing I have noticed apart from a naff Brimistor and a o/c dropper, is quite a few split caps and a couple of burnt ones on the R/F section, they are those awfull Hunts miniture mould things there are 29 of them !!!! 0.001 uf 350 v there is so little room,I think I can remove the whole section from the chassis which should help a bit, can anyone suggest what I replace them with this is going to be a nasty fiddly job
tvden is offline
Old 28th Sep 2005, 9:09 pm   #2
Danny
Danny's Avatar
Default Re: PYE LV 30 RF section
Hi den i would use litle blue disks thay ar cheap and small or if you want bigger caps i use the yellow ones from cpc . used disks in my lv30 with no problems .
Danny is offline
Old 28th Sep 2005, 9:52 pm   #3
tvden
tvden's Avatar
Hi Danny many thanks for that idea I had not thought of using disks, I will order some tomorrow from RS, I have got the r/f pannel out now so I will have a bit more room to play with, there does not seem very much in this little set but its fiddly, I had hoped with a few choice waxys replaced and a temp dropper assy to fire it up and see if I had any life but all these Hunts have put paid to that now , this is the console set, when I come to do the table model I will have a bit more experience but still loads of problems
tvden is offline
Old 29th Sep 2005, 10:34 pm   #4
Danny
Danny's Avatar
yes sadly you will have to hunt the hunts out to cure future problems as thay will cause so much trouble you will end up insane like me!.
Danny is offline
Old 4th Oct 2005, 8:10 am   #5
DoctorWho
DoctorWho's Avatar
I have both the console and tabletop versions of this set. When I got mine I was rather horrified with these little Hunts horrors. I ordered a supply of 1000pf @ 450V from Maplins and then got down to each set. I found a number of these in very awkward places and very well hidden, it's very easy to miss one, I also believe there were one or two outside of the RF assembly if memory serves me correctly.
I noticed that most of them went to chassis on one side (you need to verify this with each one), so I carefully went through and replaced every one, but I didn't do the chassis connections until I had got every replacement condenser in place. Once I had done this I then carefully connected them to chassis, sometimes sharing a common connection with a number of the condensers. This did make it much easier.
When completed both sets worked well and are still giving a good reliable service.
I hope this may be of a little help.
Peter.
DoctorWho is offline
Old 4th Oct 2005, 8:36 am   #6
oldeurope
oldeurope's Avatar
Good morning,
are you talking about these?
I think the RF strip is the same in the FV1.
Kind regards Darius
Name:	V4 def. Fassung ohne Schirmblech.JPG
oldeurope is offline
Old 4th Oct 2005, 9:15 am   #7
Heatercathodeshort
Heatercathodeshort's Avatar
Hello Darius,
Very similar to the FV1 but the LV30 is TRF. The FV1 was PYE's first five channel superhet [FIVE VISION ONE] and continued with the FV2 and FV4 series. Great sets that give superb pictures. Alas all HUNTS horrors! Regards.JOHN.
Heatercathodeshort is offline
Old 4th Oct 2005, 4:29 pm   #8
brianc
When restoring my LV30, I , like Den, removed the RF chassis to give better access. After changing the caps etc. I powered the chassis using a variac for the heaters and a bench HT supply. This meant that I could prove my work before re-installing it in the main chassis and made alignment very easy. This also worked very well with a Pye B16T (My bench is fitted with an isolating transformer so there was no risk using the variac)!
Brian
brianc is offline
Old 5th Oct 2005, 9:07 pm   #9
tvden
tvden's Avatar
Hi all thanks for your input on this, I have been held up on this set waiting for some more caps to arrive, I now have them, there was also nasty 600v ac wax cap on the main tagboard, I finished the r/f chassis ok it was a bit tight in places !!! but not as bad as I had thought it would be, in the end I managed to get some 100pf 650v Vishay miniture caps !!! the same size as the ones I was replacing,I have made a temp mains dropper up and I am now replacing caps in the frame timebase ect, enough to try and fire the set up without causing damage.
tvden is offline
