27th Mar 2016, 10:36 am | #1 |
Beocord 1200 - Out/In Connections
Hi Guys,
I've got the chance to buy one of these (unseen) but I can't find any pictures of the connections anywhere online, I'm a bit wary of buying anything by B&O in case they have some sort of bespoke connections. Will I be able to plug this unit into a standard HiFi Amp? and conversely is it easy enough to plug into to record? Does it have standard in/out phono connections? Thanks for you help... Mark |
27th Mar 2016, 11:44 am | #2 |
Re: Beocord 1200 - Out/In Connections
Have a look at www.beocentral.com/beocord1200 for some more info. I imagine that a machine of this vintage will have DIN sockets rather than phonos. My Beocord 1800 has three and I found out what does which through experimantation because B&O are fond of using hieroglyphics instead of worded labels. I connected mine to a Leak Delta 30 amp without any problems, so any amp with line level in/outs should be OK. Cheers, Pete.
27th Mar 2016, 12:19 pm | #3 |
If it is DIN then the output should connect directly to the line in of an amp (Pin3 LH, Pin 5RH)
However the input level will need to be fed through a resistor of about 470Kohms to cut the level down (Pin 1 LH, Pin 3 RH) Pin 2 is ground. Some take decks have a high level input on another socket. |
27th Mar 2016, 2:34 pm | #4 |
Just to make this clear, DIN standards for tape recorders and amplifiers are mirror image, to allow pin-to-pin DIN leads to perform the usual functions. Thus:
Amplifiers : Input Pin 3 left, Pin 5 right, Pin 2 earth Output Pin 1 left, Pin 4 right, Pin 2 earth Recorders : Input Pin 1 left, Pin 4 right, Pin 2 earth Output Pin 3 left, Pin 5 right, Pin2 earth Also, the DIN standard is written in terms of current drive rather than voltage, hence the apparently high sensitivities and the need for attenuation resistors. Incidentally, the pins run round the plug in this order - 1,4,2,5,3. |
27th Mar 2016, 3:47 pm | #5 |
I have such a tape recorder.
I has DIN sockets on the bottom for 'radio' (line level stereo input and output) and 'aux' (another recording input (only) at a similar level). There are also 4 phono sockets on the bottom which carry the same signals as the 'radio' socket, but IIRC the input levels are not the same (there are resistive attenuators in series with the phono sockets). There are also a pair of DIN sockets for microphones on the left side of the control panel. These are wired so you can plug a pair of mono microphones in (one to each socket) or a stereo microphone. In one socket the latter gives the channels the normal way round, in the other it swaps them (according to the manual if you suspend the microphone upside-down) Finally there is a 1/4" jack socket on the right side of the control panel for monitoring headphones (or replay to headphones). As it's only a 2-head machine this is not an off-tape monitor in record mode, of course. There is no built-in speaker amplifier. The Beocord 1600 is the same machine with such an amplifier fitted, essentially. You certainly don't have to use it with a B&O amplifier. It will work with just about anything, and the connections are standard. |
