10th Mar 2019, 9:18 am | #1 |
Philips 387U component
I have a Philips radio from the mid 1940s with an unusual component in it. It is a relay I think. Associated with the filament circuit. When the radio is cold the contact is closed, but opens after the radio warms up. If you close the contact, the dial lamp goes out. Is this some kind of soft start device? I attach a pic of the relay and part of a circuit of a similar radio, I don't have a circuit diagram for the 387U.
10th Mar 2019, 10:00 am | #2 |
Re: Philips 387U component
Well its a relay alright.
Never seen that set, Aussie model? Without the full diagram I guess same as you that it controls something as it warms up. Philips did like to complicate things! The usual knowalls will be along soon to help, bless them, what would we do without them? |
10th Mar 2019, 10:35 am | #3 |
Fast warm up?
10th Mar 2019, 10:42 am | #4 |
10th Mar 2019, 10:51 am | #5 |
Pilot lamp saver?
10th Mar 2019, 11:13 am | #6 |
10th Mar 2019, 12:01 pm | #7 |
I'd go with MM. Cold heaters in series with pilot lights usually means dim pilots are the result of the usual resistor/thermistor protection schemes. Looks like an engineer's rather than bean counter's approach to the problem.
It's Philips, too- why use one cheap component when several plus a relatively expensive relay will do?
10th Mar 2019, 1:04 pm | #8 |
In this one the relay coil supplies the bias for the valves via some taps:
http://www.philipsradios.nl/Schemas/657U.pdf Lawrence. Last edited by ms660; 10th Mar 2019 at 1:33 pm. Reason: addition |
11th Mar 2019, 12:09 pm | #9 |
Either for faster warmup, protection of the lamps or both.
