10th Feb 2020, 7:04 pm | #21 | |
Re: Peak Atlas ESR tester
Mike |
10th Feb 2020, 7:19 pm | #22 |
How about fitting a sprung dpdt switch between tester and the croc clips or whatever. Normally, both poles switched into say a 47R wirewound resistor, until you press the switch to connect clips through to tester?
Cheap and simple. Rob
10th Feb 2020, 7:46 pm | #23 | |
Apart from all this, do the Peaks have other advantages over the cheapies? And they certainly are cheap by comparison! I know that their wider functions aren't accurate for germanium junctions, but perhaps the Peaks are also silicon-only (talking about the models that include semiconductor testing). Mike |
10th Feb 2020, 8:26 pm | #24 |
My Peak old DCA55 and new DCA75 correctly identify Germanium and Silicon parts when testing.
Chris Wood BVWS Member |
10th Feb 2020, 8:42 pm | #25 |
Boulevardier wrote: "But for a large capacitor discharge might take longer than it took you to operate the biased switch, so the Peaks' "programmed" approach would be safer. "
What I meant was biased so as to put the resistor continuously across the "probe" contacts. Operate the switch (removing load) to test with the esr meter. 3 Pole switches are available. Rob
10th Feb 2020, 9:04 pm | #26 |
How high a voltage (charged capacitor) will these testers safely discharge?
poppydog |
10th Feb 2020, 9:06 pm | #27 |
See post #18
10th Feb 2020, 9:08 pm | #28 | |
Mike |
10th Feb 2020, 9:11 pm | #29 |
10th Feb 2020, 9:17 pm | #30 |
The only thing I'd say about an ESR meter, is that it's a 'one trick pony' as compared to a multi tester. I've got an older DAC50 and a DCA 55, which was an impulse buy when Maplin briefly had an offer - about £20.00 I think - I wouldn't have paid much more. I don't want to knock Peak equipment, which enjoys a high reputation, is British made, and to all accounts has excellent backup support and helpful staff. That said, neither the DAC50 or DAC55 compare favourably with Chinese multi testers when testing FETs. I've mentioned this before, but it's relevant to this thread.
First pic below is of a JFET on the (quite old) DAC50 which claims to test FETs but never has. It thinks what it sees is a diode. Second pic is the JFET on the DAC55. If identifies it correctly as a P Channel JFET. Third pic is to identify the JFET connections, but can't identify the Drain and Source. Fourth pic is a Chinese Multi tester - no difficulty in identifying that it's a JFET and the pinouts. Fifth pic is a second Chinese Multi-tester. As with the first, it correctly give the pinouts, and the data is consistent with the other Chinese tester. (I've got a third Chinese tester which came as a kit as a gift from a forum chum and that too, gives consistent results). I don't need yet another tester, but if I did, It would be the ubiquitous MK-328, which is an LCR, transistor and and ESR meter. It has some limitations in that it won't test caps below 30pF or low inductances, but then neither would a Peak ESR meter or transistor tester. The full spec of the MK-328 can be found at one of the many ebay sites that sell them, but I've shown an Amazon link, where at £21.95 post free it costs a few pounds more than from China but you get it in a few days rather than a few weeks. https://www.amazon.co.uk/ROKOO-Trans.../dp/B07429JHJ5 Not trying to start a 'beauty parade' of ESR meters, and really, the original question about the Peak Atlas ESR meter has been well answered, but I thought some comments about the limitations I've found with the DAC55A when it comes to testing FETs were worth a mention. Hope that's of interest.
10th Feb 2020, 10:10 pm | #31 |
David - thanks, you give (as usual!) a very interesting and thorough breakdown. The Chinese (mainly ATmega328 based) testers really do seem to run rings around any single Peak instrument - I even came across one offering IR testing). And most can be had for under £10! But it seems that all of them lack protection against connection of charged capacitors.
At that price it would be well worth fettling one to try and provide some protection against charged capacitors (let's face it, even the most careful of us is probably going to slip up on that eventually). I've been trying to think of an effective way of doing that. A biased "start" switch as suggested by Robinshack might be a start, though large capacitors might need a carefully considered delay before operating the start switch. Still thinking... Mike |
10th Feb 2020, 11:52 pm | #32 |
I'm very happy with the second hand Peak ESR60 I bought last year, I did consider the ESR70 but didn't need the buzzer or the extended ESR range it provides, if the capacitor ESR is higher than the ESR60 can measure I figured it's probably junk anyway.
David |
11th Feb 2020, 10:33 am | #33 | |
That said, a homebrew ESR meter can be simply and accurately calibrated, and will perform just as well as a commercial digital one. The fact that the thread ran for 4 years, had 106 posts and has had 71,000 views is as much an indication of the interest of measuring ESR, and opinions as to whether to test caps in situ or not, and 'at what ESR does a good cap become a bad cap?', as it has to do with the original project. Forum member 'Top Cap' designed a stripboard layout for those that didn't have PCB facilities. (Post 29 of the thread): https://www.vintage-radio.net/forum/...esting+el+caps The thread became so involved the Joe, 'Pillenwerfer', kindly drew the strands together and created a PDF, which is attached. (I'm referred to as 'Yorkie' in that document as that's what I'm known as elsewhere). There's some information about ESR meters in general which might be of interest, and the ESR table by Bob Parker referred to in the text is attached below. I hope it's sufficiently relevant to this thread to be of interest.
