Old 20th Oct 2020, 2:59 pm   #41
Default Re: Motorola 5A7A dead.
Originally Posted by Station X View Post
Well spotted Trevor! It looks like the OP was numbering the pins anti-clockwise.
Err.... Trevor?
Herald1360 is offline
Old 20th Oct 2020, 3:00 pm   #42
daveo23
tube in
daveo23 is offline
Old 20th Oct 2020, 3:05 pm   #43
The filament supply voltage looks too low.
Old 20th Oct 2020, 3:18 pm   #44
daveo23
Here is the 1R5, looks bad, - = some mv
1 Filament = -
2 Anode =66vdc
3 Screen grids =44vdc
4 Grid of triode = -
5 Filament = -
6 Grid 3= .6vdc
7=Filament =.9vdc
daveo23 is offline
Old 20th Oct 2020, 3:52 pm   #45
Wot no filament voltage? The voltage on the screen grid suggests the tube is passing current though.
Station X is offline
Old 20th Oct 2020, 4:31 pm   #46
daveo23
I wiggled the tube around and was able to get .9vdc but thats still too low, right
daveo23 is offline
Old 20th Oct 2020, 5:04 pm   #47
Check the voltage between pins 1 and 7.
Old 20th Oct 2020, 6:00 pm   #48
daveo23
I checked all the tube filaments, 1&7, same at .9vdc so I looked at the voltage at the end of r-6(double 1000ohm res) it was 6vdc.
daveo23 is offline
Old 20th Oct 2020, 9:34 pm   #49
Before tackling the heater problem I'd check the voltages on the other two valves to make sure plate and screen grid voltages are present. Let's not forget that the original problem was the the B+ voltage was being pulled down.
If the 1S5 (audio amplifier) and 3S4 (output tube) are working correctly you should hear a buzz or click from the speaker if you touch the centre tag (wiper) of the volume control with the metal blade of a screwdriver.
Don't forget that the service manual linked to in post #3 gives resistance values from every tube pin to chassis. It would be useful to check these.
Old 20th Oct 2020, 10:56 pm   #50
daveo23
That screw driver trick worked..bzzzz
Now the crazy question about the 1s5, how can you have 2 different voltages for pin 1 and 2 when they are connected?
Here are the 1u4 and 1s5 voltages:
1U4
1 Filament=4
2 Anode =67
3 Screen grid =67
4 = .6
5 Internal connection=4.1
6 Grid 1=1.3
7 Filament =3.2
1S5:
1 Filament=.9
2 NC =.9
3 Anode of diode=.7
4 Screen grid =20
5 Anode=20
6 Grid 1=.4
7 Filament=1.8
daveo23 is offline
Old 20th Oct 2020, 11:41 pm   #51
Pin 2 isn't connected to anything inside the tube. It's connected to pin 1 externally to provide a convenient termination point. US terminology is Tie Lug or TL.
Old 21st Oct 2020, 1:14 am   #52
daveo23
Look at the sams photofacts for the 1s5 and you can see what iam talking about
daveo23 is offline
Old 21st Oct 2020, 9:06 am   #53
There's probably been a production change at some and the routing of wires has been changed. There are many different ways of connecting a number of points together.
The bottom line is that the set worked before with pins 1 and 2 linked together, so it should work now barring any other faults.
The main problem at the moment is that filament voltage is low at 0.9V when it should be 1.4V. There are several resistors in the filament circuit which could be causing the problem. I would suggest taking resistance readings on pins 1 and 7 of all valves at the very least and comparing them with the service sheet. Note that there are two sets of readings, one for the set switched to mains supply and one with the set switched to battery supply.
Old 21st Oct 2020, 1:20 pm   #54
Given that you only have 6V on pin 7 of the 3S4 when you should have 7.9V, a likely scenario is that R17 1000R + !000R or R4 150R have gone high in value.
Old 21st Oct 2020, 1:42 pm   #55
daveo23
Before taking the filament resistance, pull the tube right? The directions say not to measure the filaments with an ohm meter.
daveo23 is offline
Old 21st Oct 2020, 1:52 pm   #56
Yes pull the tubes.
I'd suggest moving straight on to checking R17 and R4 though.
Old 21st Oct 2020, 2:36 pm   #57
daveo23
r-4=184ohms
r-17=1meg
r-8=980 each side
resistance on 1r5 looks good except for pin 6=0
1r5 resistance
1=0
2=5k
3=29k
4=106k
5=0
6=0
7=9
daveo23 is offline
Old 21st Oct 2020, 2:49 pm   #58
0 what? If it's ohms the pin is short-circuit to ground.
There are a whole load of resistors in series from 1R5 pin 6 to ground ie R1, R10, R12, R13 and R14. Their total value is about 9 Mohms.
Old 21st Oct 2020, 3:05 pm   #59
The valve filaments should draw 50mA which will give a volt drop of 98V across R8 (1960R). There'll also be a volt drop in R4 (184R) of 9.2V. In practice the volt drop will be a bit more as R4 also carries the B+ current. Even so with 120V mains there should still be enough voltage for the heaters.
Check the volt drop across R8 and the voltage wrt ground at the junction of R4 and R8.
Old 21st Oct 2020, 3:36 pm   #60
The current flowing through R4 would be typically at least twice the value of the total load current.
