3rd Jan 2020, 11:50 pm | #1 |
Component ID help
hi all
need some second opinions as to the values of the 2 resistors on this poor res schematic. there circled in red. thanks |
4th Jan 2020, 8:28 am | #2 |
Re: Component ID help
There's a slightly better circuit shown in this thread, I've copied and attached it
https://www.vintage-radio.net/forum/...ad.php?t=97165 John |
4th Jan 2020, 11:13 am | #3 |
Hi!
Mouser UK stock precision resistors of this type , failing that, I'm fairly sure you should be able to make up the values of 1.28 ohms and 121.6 ohms by selecting them from a batch of 1.2 & 120 ohm nominal components! Chris Williams
