11th Sep 2021, 11:49 am | #1 |
Garrard Synchro-lab 65 middle spindle
Hello to alls
like i say some wek ago i buy a "non working" Sl-65 i just finished to redo teh grease enterly. and in mechanical level alls work perfect now! but asdly the machine are fited with a little middle spindle for some reason? so first of alls i search a way for take it of. i dont even see how i can do taht.... and secondly where i can fin d a otehr one? can i use the one from the bsr i used lately? and also what needle i can put in this machine? i want play 33/45/78 rpms and i dont mind to change needles betwen the LP and 78. thanks for you future replys! |
11th Sep 2021, 7:01 pm | #2 |
Re: Garrard Synchro-lab 65 middle spindle
Hi, at a guess the Auto spindle for a number of Garrard autochangers should fit this deck, try searching eBay for terms such as "Garrard Autoslim/AT6(or 5) or 3500/2025 Spindle" A BSR spindle won't fit. I've found one here
The stylus required for the current cartridge in your deck would be a Shure M44 or M55. To play 78's your best bet would be to try and obtain a second headshell for the arm, a headhsell for the SP25 MkII will be fine, and fit something suitable for playing 78's; I'm sure other members would be able to advise on cartridge types. headshell here Regards Andrew Last edited by AndiiT; 11th Sep 2021 at 7:07 pm. |
11th Sep 2021, 7:04 pm | #3 |
I found a nearly identical turntable in the street about a month ago. It too had the short spindle and I couldn't remove it. The cure was to heat it with a soldering iron and lift it out with pliers.
Garrard decks of this age always have grease which turns into glue! I also had to free the main cam and trip pawl - again, using heat from the soldering iron - see the thread in this section for guidance if necessary. Do not use force!!
Regards, Ben. |
12th Sep 2021, 3:55 pm | #4 | ||
sadly the head shell not delevery in france.... (that start to be sadly common from UK seller now :/) i guesse for a 45 rpm adaptator i need a specific one too? or the BSR one can fit? i see some various 45 rpm adaptor like this one : https://www.ebay.fr/itm/203514227700...gAAOSwaRhgSGoS Quote:
i hope is a good automatic turntable. there also somthing strange. is a magnetic cartidige right? but the plug from the turntable actualy only get 3 pins. so tehre no grounding to the amp? thanks a lots for the help ! soon i motly got a nice machine with alls of that . ^^ |
12th Sep 2021, 11:21 pm | #5 |
Pin 1: Left signal
Pin 2 (centre/top): combined ground Pin 3: Right signal
Regards, Ben. |
14th Sep 2021, 4:19 pm | #6 |
22nd Sep 2021, 9:51 pm | #7 |
thanks alls for your helps !
now is work like a charms. i replace the old 3DIN plug by two RCA plug + ground for totaly delete teh HUMMM noise. the turntable sound beter than my AT-LPT3 so is now my main turntable. next step is find the 45rpm adaptor. i see some LS20 . |
