7th Sep 2021, 5:23 pm | #1 |
Lightbulb of a valve.
I replaced a D77 valve in my GEC, with what was said to be an equivalent by The Valve Museum, an EB91. I switched the set back on and the entire back lit up.
Having a look the valve was more of a lightbulb! I’ve never seen a valve glow so bright before. Obviously something isn’t quite right so I swapped it back for the original D77 which glows normally. Are the EB91 and D77 not equivalents? Not being familiar with valves I wondered if maybe they do glow bright or maybe it’s faulty? Just thought it was interesting Thanks ‘77 |
7th Sep 2021, 5:54 pm | #2 |
Re: Lightbulb of a valve.
They are equivalent, but that certainly doesn't look right. Maybe the EB91 is faulty or mislabelled.
Can you see the double diode structure within the valve? I wonder if it's actually a Dx9x with a 1.4V filament. |
7th Sep 2021, 5:55 pm | #3 |
The EB91 is well known for it's illumination properties at switch on but should settle down very shortly after.
Lawrence. |
7th Sep 2021, 6:10 pm | #4 |
I wonder if there is a short between heater and screen. Do you have a valve tester? If not, maybe try another EB91.
7th Sep 2021, 6:10 pm | #5 |
There are EB91’s in my TV22, and none of them glow that brightly!! Even when the decouplers shorted out! Show us a photo of the valve close up, so we can see what’s in it. Also if you have access to a power supply capable of 6.3V or there abouts, you could try powering the valve heater from that and see how bright it glows.
Regards Lloyd |
7th Sep 2021, 6:13 pm | #6 |
What type and model of GEC is it?
7th Sep 2021, 6:30 pm | #7 | |||||
I tried taking some photos but my phone just didn't like it. It was either blurry or grainy so the photos are useless, but it looks identical to the one here if that helps. No power supply either at the moment, would like to get one though Quote:
Thanks all '77 |
7th Sep 2021, 6:54 pm | #8 |
Happy to test the valve for you if you would like to send it. (tester, not a set)
7th Sep 2021, 7:33 pm | #9 |
Thank you, I'll take you up on that offer if you wouldn't mind, just out of curiosity. Not sure when I can post it but it wont be too long.
Thanks '77 |
7th Sep 2021, 7:38 pm | #10 |
Will PM you details.
16th Sep 2021, 2:17 pm | #11 |
If not too late to the party, isn't the EB91susceptible to heater-to-cathode leakage?
Not quite sure that would make it glow like a bulb however. |
16th Sep 2021, 3:37 pm | #12 | |
Lawrence. Last edited by ms660; 16th Sep 2021 at 3:42 pm. Reason: extra info |
17th Sep 2021, 9:11 am | #13 |
Recommend if you post a valve and choose to put it in a stout cardboard tube, it works out cheaper if you then put the tube inside a square or oblong box! Having seen the sorting hubs the conclusion i came to is that poster tubes cause problems on the conveyor belts and have to travel a different path.
Dave |
18th Sep 2021, 1:43 pm | #14 |
As the valve is 17mm diameter, I put this size in a couple of inches of 3/4" or 18mm plastic water pipe.
Keeps them safe.
Valve equipment repairs since 1968 https://jonsnell.co.uk |
18th Sep 2021, 1:54 pm | #15 |
I have a large number of 6AL5's if you need any more.
John |
18th Sep 2021, 9:39 pm | #16 | |||
Good to know though for future reference, so thank you both, will keep that in mind Quote:
Thanks all '77 |
