Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
15th Dec 2010, 11:28 am | #1 |
Aurora Question
Hi all, i have just bought myself an aurora, in the instructions it states "If the television is of the 'hot chassis' type where it is connected to one side of the ac mains, then an isolation transformer should be used between the converter and the television"
As all the tv's i have are ac/dc sets, i was wondering what do others use for isolating thier Aurora? Mark |
15th Dec 2010, 11:48 am | #2 |
Re: Aurora Question
This is an extra precaution in case the TV chassis is actually live and the aerial isolator breaks down. If you ensure that the chassis of your set(s) is neutral then there is really no risk in connecting the Aurora directly. A small box with isolating caps (Class Y 2n2 or 4n7 is ideal) in both centre and screen is all you need as an additional isolator.
15th Dec 2010, 11:52 am | #3 |
Re: Aurora Question
Thanks Jeffrey, i just wanted to be sure before connecting it up, as i have to make up a lead from the aurora to the tv, i will fit the caps as you suggest.
Mark |
15th Dec 2010, 11:55 am | #4 |
Re: Aurora Question
As Jeffrey says I assumed the aerial socket on the TV should be isolated from the chassis and I always replace the components which do so to be sure and ensure the chassis is at neutral. Maybe this is wrong but my Aurora also sits behind a dist amp with further circuit prevention, am i'm wrong but is this also a good method should anything fail.
15th Dec 2010, 12:05 pm | #5 |
Re: Aurora Question
You could make a lead with an F plug on one end and a small plastic box (35mm film container?) on the other. The box has a co-ax socket and 2 caps inside. Strictly there should be a bleed resistor (1M or greater) across each cap.
15th Dec 2010, 12:28 pm | #6 | |
Re: Aurora Question
Yes it can help, but really only if the distribution amp is earthed, I run four channels here, three with programmes and one continual test card. If your isolator caps are duff you will soon know about it, if faulty your RCD will trip and if the chassis is live no doubt there will be some fuse blowing. A little tip try to always fit a 1 or 2 amp (dependant on the set) fuse in the plug top. If you cannot get them locally CPC do them.
15th Dec 2010, 12:30 pm | #7 |
Re: Aurora Question
Hi Trevor, yep it's earthed, perhaps another option Mark can consider too.
Chris |
15th Dec 2010, 12:56 pm | #8 |
Re: Aurora Question
Just to emphasise that this is true even if the chassis is neutral.
15th Dec 2010, 1:04 pm | #9 |
Re: Aurora Question
I have found a tiny diecast box & some suitable caps, so will get the soldering iron out
I am very carefull to check that chassis is connected to neutral, i also have an rcd, the sources i will be using (freeview/dvd/video) are all double insulated. Better safe than sorry.... Mark |
15th Dec 2010, 1:07 pm | #10 |
Re: Aurora Question
15th Dec 2010, 1:39 pm | #11 |
Re: Aurora Question
Yes, the aerial socket & Coax plug would go live too with faulty caps!
I always replace the caps in the aerial isolator now after being caught out before!
15th Dec 2010, 1:58 pm | #12 |
Re: Aurora Question
My converters are isolated by virtue of filtering, slight amplification and an air gap so no danger of them being blown up by a vintage set!
Brian |
15th Dec 2010, 2:00 pm | #13 | |
Re: Aurora Question
Mark |
15th Dec 2010, 2:51 pm | #14 |
Re: Aurora Question
I suppose that you could line the plastic box with foil if screening is a concern.
15th Dec 2010, 5:11 pm | #15 |
Re: Aurora Question
You can also buy commercially-built units that just fit inline, anywhere from 5-15 quid
Kevin |
15th Dec 2010, 6:15 pm | #16 |
Re: Aurora Question
There was no such warning with my Aurora. Maybe a few have been blown up?
Mine is fed by a 12V PSU of the wall type which uses an isolation transformer. I assume that such PSU's are approved for isolation? The sets are always plugged in with neutral to chassis anyway. Just a thought. How about a few turns of a coil with another few turns interwoven in the lead from the Aurora to the set to isolate? |
15th Dec 2010, 6:38 pm | #17 |
Re: Aurora Question
I personally have never has a problem and being honest I really doubt anyone has.
For many reasons any set should have the aerial isolating caps replaced with suitably rated caps, remember the aerial socket is easily accessible to non technical personnel on most sets, and if children are near your TV's and get a belt, well you wouldn't forgive yourself. Changing the caps to decent X rated types or suitably rated ones will also render the Aurora safe and obviate it from damage. Always make sure the chassis of the TV or TV's are connected to neutral.
15th Dec 2010, 6:44 pm | #18 |
Re: Aurora Question
AFAIK there have not been any incidents. However there is the possibility of an accident so it's best to issue the warning. For my own usage I'm not sure I can be bothered with an isolator. My main precuations are making sure the chassis is neutral and using an RCD.
16th Dec 2010, 4:56 pm | #19 | |
Re: Aurora Question
X-rated capacitors are intended for wiring across the mains, and will never catch on fire. Y-rated capacitors are intended for wiring between mains and earth, mains and exposed metalwork or mains and SELV circuits, and will never fail in a low-impedance state. (This probably should be stickified somewhere.)
If I have seen further than others, it is because I was standing on a pile of failed experiments. Last edited by Dave Moll; 16th Dec 2010 at 5:04 pm. Reason: quote fixed |
16th Dec 2010, 5:40 pm | #20 |
Re: Aurora Question
Hi.
I have had problems with both X & Y types of caps, I have a nice little box of nasties! The failure rate is tiny but of the faulty X types they mostly suffer with low value, I have three Y types here that have a nice brown burn mark on their bodies, and all three are dead short! I fit X types and have not had a failure here but that is because I have hundreds of X types I also have some 47nf marked XY so what is that all about?
