6th Oct 2015, 5:11 pm | #1 |
More Odd Bulbs.
One of these two are marked is marked 10Volts 240 Watts.The other is very similar but unmarked.
Ex fairground? I await with intrest any comments. Thank You David
G8JET BVWS Archivist and Member V.M.A.R.S Last edited by HamishBoxer; 6th Oct 2015 at 5:19 pm. |
6th Oct 2015, 5:43 pm | #2 |
Re: More Odd Bulbs.
Movie projector?
6th Oct 2015, 6:34 pm | #3 |
Re: More Odd Bulbs.
Could be though 1930,s I guess.
6th Oct 2015, 6:54 pm | #4 |
Re: More Odd Bulbs.
Some random speculation...
240W is too low a power for a cinema projector (which at that time probably used carbon arc lamps). It's about right for a domestic projector, but most of those used a 110V or so bulb with a series resistor and not a step-down transformer (possibly due to the use of DC mains in some areas). The base of those bulbs suggests they were designed to be accurately positioned (as opposed to a screw cap) in an optical system, perhaps a reflector or condensor lens type thing. I doubt they were for general illumination use. 10V is also odd, it doesn't suggest running off a car battery or other vehicle battery. On the other hand, taking 24A suggests either a lead acid battery (5 cells?) or a transformer as the power source. Some kind of small portable-ish spotlamp? Is that 'BTH' on the base? Britiish Thompson Houston ? |
6th Oct 2015, 7:28 pm | #5 |
Re: More Odd Bulbs.
Signalling lamp? It's not the same flange or filament arrangement as an Aldis but nevertheless... And using a 10V bulb at 12V would give a faster response - possibly the filament arrangement is to absorb the mechanical stresses of repeated off-on cycles?
Cheers, Colin. |
6th Oct 2015, 8:05 pm | #6 |
Re: More Odd Bulbs.
Low-voltage high-current bulbs were often specified for things like ships' navigation-lamps because their thick filaments were relatively robust so more-immune to the shocks of traversing stormy seas (and, in the case of warships, the effects of firing serious-calibre guns!).
6th Oct 2015, 8:11 pm | #7 |
Re: More Odd Bulbs.
I'd certainly say they were part of an optical system of some sort, as the filaments are constructed to approximate a point source.
6th Oct 2015, 8:17 pm | #8 |
Re: More Odd Bulbs.
Just checked with a head magnifier and both are 240W at 10 volts.Cannot see BTH but there a number(s) 5L/1818 on one.
6th Oct 2015, 8:20 pm | #9 |
Re: More Odd Bulbs.
I think that it is for a signalling lamp.
Such a thick filament wont respond very quickly to on/off switching and was probably intended for the type of signal lamp in which the bulb is lit continually and signalling achieved by a mechanical shutter that somewhat resembles a venetian blind. A very compact filament is needed to achieve a narrow beam angle which is required for two reasons, firstly concentrating the light into a narrow beam makes it brighter to the intended recipient, and secondly makes it less visible to others such as the enemy in wartime. Such signalling lamps often incorporate a small telescope to assist in accurate aiming. Commonly called Aldiss lamps, but that is a trade name and other brands exist. 10 volts is probably for use on a nominal 12 volt circuit, either from a portable battery, the voltage of which will drop under such a heavy load, or to allow for voltage drop in some yards of cable if connected to the electrical installation of a boat or vehicle. |
6th Oct 2015, 10:26 pm | #10 |
Re: More Odd Bulbs.
5L/1818 could well be a pre-NATO UK Forces stock number.
7th Oct 2015, 11:12 am | #11 |
Re: More Odd Bulbs.
I am very grateful for all these thoughts and if there are any more please keep them coming.
7th Oct 2015, 11:26 am | #12 |
Re: More Odd Bulbs.
Definitely from a signalling lamp - I replaced one or two when at gliding school in the air cadets (1963/4). We used the lamps for signalling to the winchman. We had Aldis and other makes, and these were in the "other" makes.
Colin |
7th Oct 2015, 11:50 am | #13 |
Re: More Odd Bulbs.
Thanks Colin and there I was thinking they were rare and even valuable!They look so 1930's but I guess not so.
7th Oct 2015, 12:54 pm | #14 |
Re: More Odd Bulbs.
They're probably a thirties or earlier design. No point reinventing the wheel......
7th Oct 2015, 4:26 pm | #15 |
Re: More Odd Bulbs.
Possibly valuable to anyone who has an old signalling lamp and wishes to restore it. Naval museum ? anyone with an old ship that they want to keep original perhaps.
Special purpose bulbs tend to be very expensive even when new, replacements for current Aldiss lamps are over £60 each. "A daylight signalling lamp, not dependant on the ships main electrical system" is still a legal requirement for all ships over a certain size. Anything required by law tends to be expensive. |
7th Oct 2015, 4:33 pm | #16 |
Re: More Odd Bulbs.
I did not think that much.Anyway not thinking of selling them just yet.
