Old 4th May 2023, 9:15 pm   #1
river9999uk
Default I broke it! :-( Sony TC630 reel to reel restore gone wrong
Hi
I have been restoring my late uncles Sony TC630 reel to reel player and it had been going rather well. Freeing up all the parts due to the cement like grease and from totally seized up it was running. I was on the last part, the pinch roller lever bar which was stuck and it would not come off at all. Sadly in trying to remove it I broke it. I am not sure if/how it can be glued/epoxyed back together or if I need to try to find a spare.
Anyone had this or tried to fix something similar. The metal is some sort of weak alloy that doesn't seem to be that strong.
Hope you can help as I was hoping I could get my uncles reel to reel back up and running and part of my setup.
Thanks in advance
river9999uk is offline
Old 4th May 2023, 10:27 pm   #2
Analogue man
Default Re: I broke it! :-( Sony TC630 reel to reel restore gone wrong
Is the break a vertical break or one that runs at an angle from the top to the bottom, if the latter it might be possible to drill two small holes and tap a small thread on one piece whilst making the holes in the other just slightly larger (clearance) for the screws you intend to use.
Graham
Analogue man is offline
Old 5th May 2023, 5:19 am   #3
TonyDuell
I have never tried it, but Machine Mart sell a kit to repair aluminium, the catalogue (although not the website) say it can be used on aluminium alloy castings too.
See :
https://www.machinemart.co.uk/p/alum...r-starter-kit/
TonyDuell is offline
Old 5th May 2023, 6:24 am   #4
dmaillard
dmaillard's Avatar
Most unfortunate, may be easier to find a parts deck, that piece is common across many Sony decks of that vintage. An attempted repair may never be strong enough.
In future it's best to use heat from small butane torch, (you can easily direct the heat to where you want it only, don't hold the torch too close though), to soften hardened lubricant, making it very easy to then remove.
dmaillard is offline
Old 9th May 2023, 1:07 am   #5
locknut
When the grease has turned to toffee, you can't beat a bit of heat to shift it. Another good source is the tip of a soldering iron directly onto the shaft or spindle.
Paul
locknut is offline
Old 9th May 2023, 7:25 pm   #6
river9999uk
Thanks for the tips...I will do that next time. Perhaps if I can't repair it I'll try to get it off again with the tips suggested and buy a spare one and get the bit off it.
