5th Apr 2012, 9:23 pm | #821 |
Re: AVO Multimeter survey
Whilst finally getting near the end of reorganising my workshop, I have unearthed the box containing the AVOs.
An 8 MK3 I've had for years, but now has an o/c meter - 8xxxx (no letter) 768 An 8 with low amps readings and very low voltage readings - 3xxxx C 1254 An 8 which is accurate, but has terminal damage - 1xxxx C 453 The 1953 one has the bakelite cover with the prod storage, but by 1954 it has the aluminium one. Also the 54 one has terminals without sockets and needs the leads with the spade ends. |
14th Apr 2012, 11:41 am | #822 |
UNIVERSAL AVOMETER
MODEL 8X Mk. III (PANCLIMATIC) MODEL 8 No. 56368 . 367 |
14th Apr 2012, 2:21 pm | #823 |
Another AVO turned up a few days ago. AVO 8 Mk V I think from 1979, no labels just the instruction plate on the rear dated 6/79, in leather case.
Andrew
Invisible airwaves crackle with life. Or they should do. BVWS Member |
14th Apr 2012, 3:42 pm | #824 |
Hi another, Avo Universal Mk7---No 1830-A-148, i presume this is a 1948 model.....regards...Alan.
14th Apr 2012, 6:30 pm | #825 |
Alan,
Your latest Avometer is from January 1948; this is around the time when the design changed from horseshoe to block magnet. If you know which you have would you please let us know? PMM. |
14th Apr 2012, 9:13 pm | #826 |
Hi, just dug out my old AVO from the Garage AVO 8 MKIII Sn 5707-1164.
I tried to clean it with foam cleaner and it stated to remove the paint from the rear panel luckily only a small patch.
Any tool can be used as a hammer but a screwdriver makes the best chisel |
14th Apr 2012, 9:35 pm | #827 |
Hi Dave, (nutteronthebus)
Nice leather case you have there, I wonder where you had that from Anyway another serial: 1487-B-548 (Model 40) Paul. |
14th Apr 2012, 10:03 pm | #828 |
I need a couple more leather cases, but they seem to command prices as high or higher than the meters themselves!
15th Apr 2012, 11:35 am | #829 |
Phil,
I have sent you a PM. Paul. |
21st Apr 2012, 10:02 am | #830 |
I have just acquired my first AVO 9SX. Serial number 8673-15-765. Can anyone provide a copy of the handbook/manual please?
Neil
An engineer makes for a penny what a scientist makes for a pound! |
21st Apr 2012, 12:46 pm | #831 |
One of the two i have has a black case that is made of something like the stuff that suit cases are made of not real leather.
The markings on it say:- Test set n.o1 MK4 and shows the nato part number:- 6625-99-728-5965 |
21st Apr 2012, 1:53 pm | #832 |
I have some of those Eveready cases with my other AVOs. The TS1 Mk4 seems to be the AVO 8 MK6 as I have a NATO stamped one with the same case you have. My AVO 9SX came with a tan leather case.
Neil.
21st Apr 2012, 2:16 pm | #833 |
Another 2 for the list, picked up today for £8
AVO Model 7 MKII - 42178-A-653 AVO Model 8 MKV - 5270-049 |
25th Apr 2012, 4:37 pm | #834 |
Avo 8 Mk2, 3808 C 763D. Now restored with a model 8 Mk4 movement and scale.
John |
25th Apr 2012, 8:16 pm | #835 |
It looks more like a Mark 1 to me, with screw-down terminals. Mark IIs usually have "Mk II" in the button below the "Model 7" legend, too, but I may be mistaken. Sometimes cases get swopped by previous owners, so the instruction plate doesn't match the meter, and I have some Model 8s in this state.
But you got an original-type battery with it, you lucky chap! Quite a bargain for the pair, though, so well done.
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 25th Apr 2012 at 8:20 pm. Reason: Point added |
25th Apr 2012, 8:28 pm | #836 |
No you are right Phil, also on the MKII the markings on the panel are engraved and white.
Yes the original battery but it was flat It was just a guy selling junk at a market, he wanted £5 for the 7 and I couldn't walk away without the other so offered £8 for the two which he took. Last edited by stitch1; 25th Apr 2012 at 8:34 pm. Reason: More info |
25th Apr 2012, 9:01 pm | #837 |
Hi pmmunro,
Your latest Avometer is from January 1948; this is around the time when the design changed from horseshoe to block magnet. If you know which you have would you please let us know? It has the horseshoe shape magnet. Regards, Alan. |
25th Apr 2012, 10:57 pm | #838 |
Alan,
Thanks for the magnet in formation; it all adds to the information the survey provides. PMM |
28th Apr 2012, 3:55 pm | #839 |
My AVO 9SX (Serial number 8673-15-765) doesn't have a scale number (1 to 12), so I assume it was hand calibrated to the movement. Does anyone know when they started using 'best match' scales or are all the AVO9s calibrated to their movement?
Neil
1st May 2012, 6:35 pm | #840 |
AVO 8 Mk III here, but cannot find a serial number :-(
The scale plate says " MODEL 8. No. [nothing visible] " so, unless someone can suggest somewhere else for me to look? Other threads on this forum very encouraging re. alternative to 15V battery pack. Last edited by Nymrod121; 1st May 2012 at 7:01 pm. |
