20th Dec 2005, 2:50 pm | #1 |
Valves for a CRT Televisor
I thought best to put this here as it is a general query on circuitry, as opposed to a definite TV question.
I have found a circuit for a CRT-display 30-line televisor in a book I got out of the University Library (Television, Theory and Practice; J. H. Reyner; Chapman and Hall, 1934) but want to adapt the circuit to use valve-types that I have. The circuit calls for 2xGDT, 1xMVSPen, 1xMSPen and 2xMHL. Looking at the circuit, the GDTs are Thyratrons, and used to generate the line and frame timebases. These I can sub 6K25s or GT1Cs for. The MVSPen and MSPen appear to be constant-current valves used to improve the linearity. The circuitry here confuses me a bit. The name implies they are pentodes, but there are only two grids drawn in the circuit (tetrodes). I assume this means the supressor grid connected to the cathode has not been drawn as it is all done internally, or am I wrong? The little information I have been able to find implies these are HF/IF valves. Is it ok then to substitute 6K7Gs or similar, so long as they can handle sufficient anode current, or should I use audio O/P or line O/P valves? The books I have seem to give little information on constant-current pentodes. The MHL triodes are used in the detector stage of the reciever, so I don't really need to include these. I want to try and use shouldered valves as they will look 'right' for a mid- to late-30s circuit! I am sucumbing to a bit of form over function! Sam
Can he lead a Normal life, Doctor? No, he will be ... an Engineer. |
20th Dec 2005, 4:22 pm | #2 |
Re: Valves for a CRT Televisor
Hi - this sounds a fascinating project! You could probably use a 6K7G or EF39 as a substitute for the MVSPen as they are vari-mu pentodes, but both are really 1940s valves and Octals. Why not go for a VP4B and SP4B (for the MSPen), both British 7-pin jobs and more authentically 1935?
Good luck! Cheers, Neil |
20th Dec 2005, 5:44 pm | #3 |
This sounds an novel idea. I've not heard of anyone doing this - though that's probably down to my ignorance.
I assume that this is planned to be a single-standard set, but wonder how difficult it would be to adapt it to dual standard to work also on the NBTVA 32-line standard in the way that Gary Millard's NBTV Viewer software does. |
20th Dec 2005, 6:07 pm | #4 | |
Out of interest which type of CRT are you using Sam? Steve |
20th Dec 2005, 7:18 pm | #5 |
Sam,
you could try the SP41 or SP61, these were used in a number of pre-war designs, but are readily available as the RAF VR65 and VR65A. The SP41 / VR65A has a 4V heater, and the SP61 / VR65 has a 6.3V heater. Jim. |
21st Dec 2005, 12:14 am | #6 | ||
The CRT will be a later type - probably an oscilloscope tube. I have a couple of 3" ones. I am trying to use this as a way to put some of the cr*p I have to use! Quote:
I will get the circuit scanned and attached tomorrow. Sam
22nd Dec 2005, 4:57 pm | #7 |
OK, here is the circuit. Looks a lot simpler than a 405-line set!
Sam
