Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 22nd Oct 2019, 4:24 pm   #1
steve.seven
Default Pye P28 Output Transformer
Looking for replacement audio output transformer for Pye P28 radio.
Thank You.
steve.seven is offline
Old 22nd Oct 2019, 7:19 pm   #2
Ed_Dinning
Default Re: Pye P28 Output Transformer
Hi Steve, it is a bit special as it has a feedback winding as well as the normal pri/sec.
I can rewind if you have no success in finding a replacement.
Ed
Ed_Dinning is offline
Old 22nd Oct 2019, 8:15 pm   #3
steve.seven
Thanks Ed, the set is in very poor condition, the cabinet is badly affected with woodworm so probably not worth the cost of a rewind but thank you for your offer all the same.
Steve.
Old 22nd Oct 2019, 9:22 pm   #4
Ed_Dinning
Hi Steve, no problems.
If you cannot get the correct transformer then you may be able to use one without the feedback winding and connect it to the speaker secondary (be careful if an AC/DC set).
You may then need to experiment with a resistor in circuit.
Ed
Old 31st Oct 2019, 9:16 am   #5
steve.seven
Hi Ed,
Replacement transformer now found from scrap donor set, thank you for your very helpful comments and advice.
Steve.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
