Old 19th Oct 2019, 9:21 am   #1
Redgate23
Default Blaupunkt Arkansas 58. Turntable not working.
Hi, I have a Blaupunkt Arkansas 58, the radio works fine but there doesnít seem to be any power to the turntable or the little spot light inside the compartment. Iím not very technical, just wondered if anyone had any tips or helpful hints. Thanks.
ID:	192118   Click image for larger version
ID:	192119   Click image for larger version
ID:	192120   Click image for larger version
ID:	192121   Click image for larger version
Redgate23 is offline
Old 19th Oct 2019, 9:46 am   #2
Audio1950
Default Re: Blaupunkt Arkansas 58. Turntable not working.
Let's start with the basics. Remove the circlip from the centre of the turntable (at the base of the spindle) and lift the turntable off. Now turn the control to "start", and see if the motor is turning.
Audio1950 is offline
Old 19th Oct 2019, 10:00 am   #3
Edward Huggins
It sounds like the mains power is not getting to the Collaro autochanger or the interior lamp. Check to see if there is a small plug in connector for these at the rear of the radio chassis. Record deck motors very rarely fail.
Edward.
Edward Huggins is offline
Old 24th Oct 2019, 9:22 am   #4
andyrols
I have a similar machine which had a different problem at the time, but as to how capable you are you might find it would be worth getting a local expert (advertised on these forums) to call out and fix it. It was certainly worth it for me - the vinyl collection is constantly used.
andyrols is offline
Old 27th Oct 2019, 11:00 am   #5
Redgate23
Thanks. We have managed to get the turntable working now but the sound is only coming from the stylus - the sound is fine from the radio but just not from the turntable. Also the arm automatically knocks the record down but then returns to the stand, it doesn’t automatically go onto the record. Not sure what all the wires are for on the back of the cabinet. The interior light is still not working on the side where the radio and turntable is, but the interior light on the cocktail cabinet side is fine.
Old 27th Oct 2019, 9:36 pm   #6
Michael Maurice
Michael Maurice's Avatar
This radiogram dates from 1957 and will need to be electrically and mechanically serviced. Just out of interest, what size records were you playing?
Forum Moderator
Michael Maurice is offline
Old 28th Oct 2019, 6:18 pm   #7
Redgate23
We were playing 45ís and we had the dial set to 45, so not sure why there is no sound coming from the speakers.
Old 28th Oct 2019, 10:27 pm   #8
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
The 'no sound from the amplifier when playing a record could be due to a faulty cartridge. The way to check this is by a 'buzz test' at the pickup lead terminals. Gently pull back any insulating sleeves over the terminals, then touch each wire in turn. One will be the common negative lead which won't produce sound, but, if the amplifier is working with the switch set to 'gram, a loud buzz will be heard with the volume control at maximum. I am assuming that the Arkansas is fitted with a double wound mains transformer so that it's chassis is fully isolated from the mains. If, by any chance it is of the 'live chassis' type, then you must make certain that the mains neutral is connected to chassis, and ideally power the set via an isolating transformer. Not being familiar with continental radiograms, I thought it wise to include this caveat in my post
'LIVEWIRE?' is offline
Old 29th Oct 2019, 7:25 pm   #9
Redgate23
Hi, so sorry but we’re both not technically minded! I’ve attached images of the back of the cabinet. We don’t know if everything is connected as it should
ID:	192626   Click image for larger version
ID:	192627   Click image for larger version
Old 30th Oct 2019, 9:48 am   #10
'LIVEWIRE?'
I'm finding it difficult to see much in those images. Maybe other members can see better what's in the pictures than I.
Old 30th Oct 2019, 9:56 am   #11
Station X
Station X's Avatar
The pick up sockets are those at the lower right of the first two pictures. You can see a representation of a turntable and tone arm.
Unplug the pick up leads, switch to GRAM and turn the volume to full. Then use a metal object such as a screwdriver to touch the metal part of each socket in turn. If the amplifier is working you'll hear a loud buzz or hum.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now
Old 30th Oct 2019, 11:39 am   #12
Ambientnoise
It’s unclear but it seems that the red and black pickup plugs are reversed. Try swapping them after the test in post 11. I think this will only affect only the audio from the turntable, not other problems.
Ambientnoise is online now
Old 30th Oct 2019, 3:54 pm   #13
Redgate23
Hi, how do you switch to Gram, is this a button on the radio at the front or is it a button/switch on the back? Thanks
Old 30th Oct 2019, 4:12 pm   #14
Ambientnoise
Think there is a button on the front, prob labelled PU (pick up, an older term for the cartridge/record deck)
Old 30th Oct 2019, 4:19 pm   #15
Station X
Station X's Avatar
To the left of the Long Wave button?
Old 30th Oct 2019, 8:49 pm   #16
Redgate23
We already had the PU switch on and we can hear a loud buzz/hum when the leads are connected - still no sound, only from the stylus. Not sure what else to try, do you think it needs a new cartridge? Thanks
Old 30th Oct 2019, 10:07 pm   #17
Station X
Station X's Avatar
Have you carried out the test suggested in post #11?
Old 30th Oct 2019, 10:34 pm   #18
'LIVEWIRE?'
I stand to be corrected, but that seems to confirm to me that the Cartridge is faulty.
Old 30th Oct 2019, 10:38 pm   #19
Station X
Station X's Avatar
I just wondered whether the buzz/hum was present with the PU lead disconnected. Having the PU lead plugged in shouldn't cause hum. There's also a possibilty the plugs could be reversed.
Old 30th Oct 2019, 10:44 pm   #20
'LIVEWIRE?'
True Graham, the bit about 'buzz/hum when the leads are connected' may be significant
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
