9th Oct 2012, 4:13 pm | #1 |
TV Coax connectors
Not sure if these are components, TV bits or old household stuff, but here's a few titbits for the anoraks, found in a collection of bits passed on to me by an ex-colleague (retired rather than literally).
Some are really nicely made, some just classic telly aerial plugs and one, the RS plug seriously weird- it seems to be a solderless type, but how to terminate it? Any ideas about the unknowns? One at any rate looks to be one of the higher quality types.
9th Oct 2012, 11:59 pm | #2 |
Re: TV Coax connectors
I believe the unknown socket to be 1960's Radiospares.
Ron |
10th Oct 2012, 1:02 am | #3 |
Here is my meager collection of plugs and sockets. I used to have some of the ones shown in Herald1360's photos with the plastic cases, others of my came from Radiospares and I have some others still attached to some cables and are slightly different to any the ones shown.
As you can see at least one of them came out of a TV set at one time or another. I used to call all of them Belling Lee connectors, regardless of who actually made them
David |
11th Oct 2012, 8:21 pm | #4 |
Are these types of co-axial connectors used on American tellies? I was always under the impression that the USA used 300ohm flat "ribbon" cable. I've got some Aerialite plugs like those at bottom right. Had 'em for years & never used 'em. Cheers, Pete
11th Oct 2012, 8:37 pm | #5 |
These are, as I call them, Belling Lee connectors, and were only used on UK sets as far a I know. The USA TV connectors are the now universal F type, but 300 ohms ribbon cable was also used for UHF initially.
I have a number of the Belling Lee connectors that I brought over from the UK when I moved to North America, as I was using them for audio at the time.
David |
11th Oct 2012, 10:02 pm | #6 |
Herald's right angle plug, and some of the plugs in MrElectronicman's second and third pictures, have annular grooves on the outside of the business end of the outer contact. I assume that this was some sort of positive detent to positively hold the plug in place in a suitably-configured socket. All the plugs shown in an August 1952 issue of a BL catalogue have this feature. Presumably it was later found to be unnecessary and not continued.
I have never seen a full-sized BL plug with such a groove, but it was a feature of the miniature version of the Belling-Lee plugs that I sometimes used in the 1970's. In the miniature connectors, the socket had an outer spring circlip with an inwardly-extending pip that engaged the groove of the plug. |
12th Oct 2012, 11:23 am | #7 |
12th Oct 2012, 11:34 am | #8 |
I've seen them on 1960s Heathkit hi-fi equipment used for audio. I don't know whether Heathkit stuff was the same on both sides of the Atlantic, though.
12th Oct 2012, 11:47 am | #9 |
Tne PA system in my school's hall included a twin deck record player console (two different Collaro autochangers, one with a "16" speed) and had a BL socket for the microphone input. I think it must have been a home brew set up dating from the mid-1950's. It was already there when I started there in 1958.
12th Oct 2012, 11:55 am | #10 | |
When it was time for a particular class to listen to one of the BBC "Schools programmes" a large loudspeaker-box [light-coloured plywood, about 2-feet-square and six inches deep with an expanded-metal grille on the front] would be taken to the appropriate classroom and plugged into the magic socket. We then all sat round expectantly waiting for the programme to start. To this day, I viscerally loathe the idea of "Music and Movement". --G6Tanuki. |
12th Oct 2012, 12:05 pm | #11 |
12th Oct 2012, 12:31 pm | #12 |
The attraction of BL coax connectors for DiY audio was the same as for TV aerials- they were CHEAP. And pretty good, too. In fact, by the late fifties for most tinkerers, they were probably pretty much free thanks to old tellies etc.
12th Oct 2012, 1:53 pm | #13 |
I still have a home-built and designed (transistorised) reel to reel tape recorder I made in the early '60s which uses Belling-Lee plugs and sockets for the low-level inputs and outputs.
As Herald 1360 says, they were cheap, and did the job OK. Being in the trade, they came at the most reasonable possibe price ;-) Also easy to mount, with 3 simple small holes. |
12th Oct 2012, 7:06 pm | #14 |
The second plug in the second picture is actually a floating socket, hence the clip on the business end.
David |
12th Oct 2012, 8:58 pm | #15 |
Coax sockets used on my dads amp and tape recorded for the BIAS/Erase connections.
Jack plugs for the audio. |
12th Oct 2012, 9:43 pm | #16 |
I also recall a Belling-Lee coaxial plug was also used to connect the microphone to the Pye Fenman II 'record maker' (magnetic disc) radiogram that my dad had in the 'fifties.
Steve
https://www.radiocraft.co.uk |
18th Oct 2012, 8:15 am | #17 |
My Rola 77 reel to reel uses these connectors (commonly called PAL connectors here) for the heads, and my father used to use them for low-level audio when he did sound effects etc in the theatre.
