28th Mar 2024, 6:45 pm | #21 |
Re: Unknown pocket 6-Transistor Radio repair project
People in the UK carried on using wavelengths for a long time. When Radio 1 changed transmitter networks in 1978 it was rebranded 'Radio One 275/285' (the wavelengths) and that carried on until Talk Radio took over the frequencies in the late 80s.
Glad you have it working. HK radios were often marked 'Empire Made' in the 60s and 70s. This was pretty much the only common reference to the (former) British Empire by then. |
28th Mar 2024, 7:22 pm | #22 | |
28th Mar 2024, 7:23 pm | #23 |
British-made pocket sets all had wavelength calibration, but most UK firms had ceased producing radios at that end of the market by 1964. Here's a Pye from the early '70s, a badge-engineered Philips, built in Singapore and still with wavelength markings. It's only very slightly larger than the average Hong Kong pocket set. G and P on the dial as well as L and M, hence probably intended for sale in France as well as in the UK.
28th Mar 2024, 10:58 pm | #24 |
This Sinclair looks to be the same radio.
https://www.radiomuseum.org/r/unknow...upreme_ga.html |
29th Mar 2024, 9:40 am | #25 |
29th Mar 2024, 12:29 pm | #26 |
Now the radio works well. It seems that it covers all the traditional broadcasting band: 180-560m. It is mostly for strong stations though... Without some "help" it gets well only TalkSport (at 300m) and Radio5Live (near 500m). That's it.
I can also hear Lyca radio around 200m (40 miles away, off topic: this stations sounds very strong in Paris 240 miles away). Regarding other stations, it can receive Premier around 200m and, thankfully my favourite local hospital radio (210m, 1 watt only!) It sounds quiet (I have to turn up the volume to max) but good where I am from 6 miles away. And that's about it. I noticed that it's more sensitive in the shorter wavelengths than the long. Without help ("help" meaning: an active antenna) it cannot get R. Caroline (which on most radios I have comes stronger than the local 1W). With an active antenna, both, the local 1W and R. Caroline sound strong, as well all others and can get BBC4 around 400m. And those are all the stations one can get on MW in my area. There is one more near 550m (Panjab Radio) but so far I haven't tuned to that - maybe because the radio is losing its sensitivity near the extreme longer wavelengths of the dial (556m). |
30th Mar 2024, 10:39 am | #27 |
30th Mar 2024, 12:01 pm | #28 |
With only one IF stage and a short ferrite aerial, I would expect it to be short of gain and lacking selectivity. If there's a strong signal close to 648 kHz, it may be 'burying' Caroline.
Andy G1HBE. |
30th Mar 2024, 12:12 pm | #29 |
I know Greg said it only has a single IF stage in #3, but it looks as if it has 2 to me. These HK sets used a very conventional 6 transistor superhet design - mixer/osc, 2*IF, driver, 2*output.
Pulling in Caroline in that location is a big ask for any basic domestic radio though. |
30th Mar 2024, 12:40 pm | #30 | |
Paul |
30th Mar 2024, 1:01 pm | #31 |
It certainly doesn't make it to Oxford, which is a similar distance. It's only supposed to be serving the eastern side of East Anglia with a tiny transmitter.
30th Mar 2024, 1:10 pm | #32 |
Radio Caroline's MW transmitter is located at the old BBC World Service site at Orfordness, Suffolk.
30th Mar 2024, 2:26 pm | #33 | |
throughout the house, with their internal antennas. Including the recently revived Vidor. And it's signal is stronger than the local - 6 miles away - 1W hospital radio. Yet in this case, while this radio receives the local hospital radio - which is crammed between Premier on 1413 and Lyca on 1458 ( meaning that selectivity isn't an issue) - it doesn't get R. Caroline. Well it didn't, today I got a faint signal but it isn't listenable. Of course with the (indoor) active antenna both stations come strong! |
30th Mar 2024, 2:29 pm | #34 |
Fair enough, I stand corrected. AM reception can be very unpredictable and depends on many factors, not just distance.
30th Mar 2024, 3:08 pm | #35 |
Given the usage of these sort of radios, it may have been dropped (more than once) and this can displace the antenna coil on the ferret rod, causing misalignment which will be more noticeable at the lower frequency end of the tuning.
30th Mar 2024, 3:11 pm | #36 | |
I have a shrill sounding transistor radio, and the recently restored mid-range audio Vidor. So I said "why not, let's see if i can have R. Caroline in (in)"glorious" pseudo-stereo. So I put the small transistor radio at the one corner of the room and the Vidor at the other... it does have a pseudo-stereo sense. But then I thought, how I can have some decent bass? Out came my R900 that has good AM/MW bass. I put that on the floor. So now I have a quasi-HiFi "system" made of of two or three radios, each covering different audio frequency ranges: - the small transistor radio acting as a twitter on the left, and a little closer , the Vidor as a normal speaker, and a little further so to create a little time delay, on the right and in the middle on the floor the R900 paying the role of the sub-woofer... A kind or 3-channel pseudo-stereo 3.1 for the vintage AM listening experience! Playing R. Caroline... |
30th Mar 2024, 4:20 pm | #37 | |
There do appear to be only two IFTs, the third smaller can would be the oscillator coil.
30th Mar 2024, 4:24 pm | #38 |
Yes, that's possible. I didn't look to see if there was a diode anywhere.
30th Mar 2024, 6:35 pm | #39 |
There is a diode although, as I don't have the schematics, and now I have put everything back, I cannot see if that is protection for putting the battery the wrong way or for detection and demodulation.
30th Mar 2024, 6:42 pm | #40 |
Reverse polarity protection is unlikely in this sort of radio. It looks like a detector.
