27th Mar 2015, 5:54 pm | #1 |
Not Veroboard
What is the stuff like Veroboard called that has no tracks but only holes with copper spots?
27th Mar 2015, 5:57 pm | #2 |
Re: not Veroboard
Matrix board.
27th Mar 2015, 8:12 pm | #3 |
Re: not Veroboard
27th Mar 2015, 8:21 pm | #4 |
Re: not Veroboard
Sometimes called prototype board
27th Mar 2015, 9:09 pm | #5 |
Re: not Veroboard
Matrix board doesn't necessarily need the spots.
I like single sided copper clad matrix board- use a vero spot face cutter (or 3mm drill) where a leg pokes through and solder direct ground connections to the plane. Wire up on the back with the component leads or TCW. 26 AWG wirewrap wire is handy for crossovers.
28th Mar 2015, 12:30 am | #6 |
Re: Not Veroboard
It was for a ribbon cable header so, as I needed it today, scored a veroboard between the holes. Worked fine.
