7th Apr 2015, 7:03 pm | #1 |
AF12x Transistor failure
As most members will know, the AF12x series transistors are usually very reliable. However, the mixer transistor (AF126 in a vintage Philips Car radio model N5X34T) had failed so that the resistance between the base and emitter of the device is ca. 95 ohms both ways round. I can't say that I've ever known an AF12x transistor to fail before
7th Apr 2015, 7:38 pm | #2 |
Re: AF12x Transistor failure
Well as they say there is always a first time.If the components are ok around that stage it is possibly just a one off.
7th Apr 2015, 7:42 pm | #3 |
Interesting and a useful alarm call. Presumably this is a junction failure rather than the AF11x tin whisker problem. Let's hope so.
7th Apr 2015, 8:10 pm | #4 |
Good point Paul. I was not even thinking about the dreaded whisker problem.
7th Apr 2015, 8:25 pm | #5 |
I have always assumed (rightly or wrongly) that the AF12x types use a different material for the case to that of the AF11x types. That being the case (excuse the pun) it won't be tin whiskers but just a one-off random failure.
7th Apr 2015, 8:35 pm | #6 |
Lets be honest...any transistor can fail even seemingly totally reliable ones. AF12x transistors must be getting on for 50 years old by now so well past their design life. If it is tin whisker, you'll be able to measure a resistance between the case and one or more electrodes.
8th Apr 2015, 9:01 am | #7 |
The transistor in question is original to the radio, which must be around 50 years old by now. There are 4 other AF12x transistors in it, all of which check out OK, plus 3 x AC12x types, but the only othe failed components were the AGC Diode (replaced by me with an AA119),which was O/C, and a very leaky main smoothing capacitor.
