3rd Apr 2015, 12:46 pm | #1 |
L.E.D lights
I am thinking of installing some blue LED lamps , 12 volt type, my question is do the lamps have a built in bridge rectifier / what supply to use , Mick.
3rd Apr 2015, 3:26 pm | #2 |
Re: L.E.D lights
Why not plump for 240V ones, no need to select a PSU then. For example https://www.tlc-direct.co.uk/Products/MLGL8101.html
3rd Apr 2015, 4:14 pm | #3 |
Re: L.E.D lights
The 12v GU5.3 types usually have rectifiers. You can run them off a transformer (but not an electronic switch mode supply used for halogens) or a DC supply.
The sticky strips do not have rectifiers and can only be run off DC. |
3rd Apr 2015, 5:10 pm | #4 |
Re: L.E.D lights
I opted for the 12v ones , because have you heard the racket produced from the mains ones.
3rd Apr 2015, 7:00 pm | #5 |
Re: L.E.D lights
I'm sure the racket will depend on the make. Ones from Philips, Osram and the like will probably be reasonable. (Noise wise, that is.)
3rd Apr 2015, 7:04 pm | #6 |
Re: L.E.D lights
My TLC ones are very quiet, it is something I do look at when selecting stuff being a radio user. OK they where 30 quid each (I have the white ones), worth it. I do ask when buying stuff 'can I return it if it interferes with my radio'.
4th Apr 2015, 8:56 am | #7 |
Re: L.E.D lights
Thanks Winston. I suspected they must have a built in rect because they can be fitted either way round . so it's the 12v ones for me, Mick.
Mods. this thread can be closed thank's |
4th Apr 2015, 10:50 am | #8 |
Re: L.E.D lights
Remember that even the 12v ones probably have a switcher in them to regulate the diode currents.
And the 'transformers' sold to power 12v lighting are usually switchers in disguise. I've got a mix of Tesco 12v halogen replacements fed from real iron transformers, and Osram 240v bulb replacement lights and HF radio seems OK. Someone else not too close by is the problem. David
4th Apr 2015, 11:18 am | #9 |
Re: L.E.D lights
If your proposed 12 volt blue LED lamps are in the standard MR16 2 pin format as used for 12 volt halogen lamps, then yes all common types do incorporate a full wave bridge rectifier and may therefore be used on DC of either polarity, or on 12 volts AC at line frequency from a copper iron transformer.
Most types wont work on the high frequency 12 volts AC that is produced by electronic "transformers" that are widely used for 12 volt halogen lamps. The internal circuitry of these 12 volt LED lamps varies. The relatively high powered lamps intended for room lighting use a switched mode or pulse width modulation circuit so as to drive the LEDs at constant power despite variations in the supply voltage. The lower powered lamps intended primarily for decoration often use a simple resistance dropper. |
