Old 20th Jan 2019, 11:59 am   #1961
Superscope
Default Re: AVO Multimeter survey
Thanks to everybody.
That's a valuable addition of Model D information.
Sinewave,
Do your Meters have the Four Digit Year shown as in Phils earlier Picture?
Don't know if it's overly important, but you never known if this information
might become useful in the future.
Now, the NATO Arrow as you called it is interesting!
NATO didn't come into existence until 1949, and that Meter is 1943.
So is it a later replacement Scale I wonder , or is the Arrow the symbol of
a different Branch of British Military?
Ian
Superscope is offline   Reply With Quote
Old 20th Jan 2019, 12:11 pm   #1962
I have this cyma Watch from WWII, which was used in WS 19 radio with the same? broad Arrow
GSTP General Service Temporary Pattern
Old 20th Jan 2019, 1:21 pm   #1963
Superscope
A quick bit of on-line research says:
The Broad Arrow or Pheon represents the Head of an Arrow or Javelin,
which were of course the Military weapons of the day back in the 15th 16th Centuries.
The Symbol has been used since the 16th Century and maybe earlier in England
and later Britain.
Originally it is believed to have meant that objects so marked were bought
from the Kings Money.
Later in British History, it was used to mark Government Owned objects which were
required by Law to be marked in some fashion.
It was commonly used by the British Military, since the Symbol had a Military background.
In short then, the Pheon could be any British Military Service, it simply means the Object
was Government Owned.
Amazing, now I have learned something today!
Also explains why I never get anything finished as I'm always Sidetracked!
Ian
Old 20th Jan 2019, 1:54 pm   #1964
Phil G4SPZ
Phil G4SPZ's Avatar
You’ll also see the Broad Arrow on O.S. trig points.
Phil
Phil G4SPZ is offline   Reply With Quote
Old 20th Jan 2019, 3:00 pm   #1965
Sinewave
Sinewave's Avatar
Yes perhaps I shouldn't refer to it as the NATO arrow.
All meters have the date in the four digit format.
Also at the bottom of the movement scale they have the writing
'B.S.F.G ACWEECO.LTD' and then 'REF No. 10S/10610'
Sinewave is offline   Reply With Quote
Old 20th Jan 2019, 5:15 pm   #1966
The Philpott
The Philpott's Avatar
I think i have heard it referred to as the WD (war department?) arrow, but the person might have been mistaken. On everything from batteries to spanners, often accompanied by the year of manufacture (which is useful.)
On many occasions i have borrowed a steel bar about 6' long, about an inch and a half in diameter, one end terminates in a wedge, the other a four-sided point. Despite the corrosion the year and arrow are still visible. It appears to be made out of some sort of unobtainium steel, is completely inflexible, quite sonorous and massively heavy- i use it in conjunction with a pivot block, for levering out small tree stumps. I think originally it was a tool for changing the links on tank/caterpillar tracks. Taken for granted for many years- but like many of the things we use it would be difficult to replace.
By comparison with the CE mark (or sometimes even the TUV mark!) the arrow effectively delivers the message- 'This is fit for purpose'
Dave
Old 20th Jan 2019, 8:18 pm   #1967
Serial number for the survey list
Avo 8 mk3 from a famous web 54204.267
Name:	Captura de pantalla 2019-01-20 a las 19.13.10.jpg
Old 21st Jan 2019, 7:07 pm   #1968
barrymagrec
My Dad`s AVO 8 mkII, owned from new. 78759-C-858
barrymagrec is offline   Reply With Quote
Old 23rd Jan 2019, 5:49 pm   #1969
Bobdger
Avo Type D 48A ser n 18025 - 1144 Printed on the scale card is the year 1949 .
Bob
Bob, BVWS member
Bobdger is online now   Reply With Quote
Old 23rd Jan 2019, 6:01 pm   #1970
Superscope
Hi Bob,
Thanks for the original Number from the 48A.
You never know, that Meter may still exist somewhere!
Although it is not on our Database unfortunately, I just looked.
Are you able to read the Serial Number from the Model D?
It should be immediately to the Left of the 1949 you mentioned, and it should begin with a D.
Ian
Old 23rd Jan 2019, 6:34 pm   #1971
The Philpott
Bob, I don't know how much you know regarding these, but as Ian says, the gist is that the Model D has found shelter from the weather in a box originally used for a Model 48A meter.
It won't therefore have any compatibility with the accessories provided, you need a Model 40, 47A, 47A(S) or 48A meter for that. There are loads of Model 40's knocking about, that would be the easiest to procure (especially the later ones).
Probably the most useful accessories are the DC current shunts, i think you have capacity for up to 480amps with an accuracy plus or minus 2%.
Dave
Old 23rd Jan 2019, 7:43 pm   #1972
Bobdger
Hi Ian and Dave
The Sn on the scale card is D104 - 1149. there is a ref number
deep below the scale front moulding 105 or 10S -10610
Thanks.
Bob.
Bob, BVWS member
Old 23rd Jan 2019, 7:46 pm   #1973
Barnmead
Barnmead's Avatar
I have been looking at the database and see that one of mine is listed three times on page 8 lines 76, 77 and 78 but perhaps you have found these?
I also have three more that could be added:
Model 8 s/n 45836-c-456
Model 8 MkII s/n 105043-c-360
Model 8 MkIII s/n 65083-867
Richard
Barnmead is offline   Reply With Quote
Old 23rd Jan 2019, 9:57 pm   #1974
Sinewave
Sinewave's Avatar
Bottom left hand corner, is that the serial number or the part number? Reason I ask is that usually, this range of hand helds has the number on the right hand, stamped/pressed into the scale plate.
What do you think?
Old 24th Jan 2019, 12:13 am   #1975
From a famous web...
Avo 7 metal case with serial number 7109-3262
Name:	Captura de pantalla 2019-01-23 a las 23.11.23.png
Old 24th Jan 2019, 12:47 am   #1976
pmmunro
Sinewave,
Post No. 1974 - That's a part number. You may find that there's a serial number indented into the scale plate at some point but the white covers the surface and there is no other filling of the characters. The serial number on some later Multiminors is like this.
PMM
pmmunro is offline   Reply With Quote
Old 24th Jan 2019, 2:00 am   #1977
Sinewave
Sinewave's Avatar
Sadly nothing on this. It's a shame as I wanted to enter this on the survey, but it's serial less. A model 71 I have has the number on a sticker, others are indented into the scale plate, but this one has nothing and will remain a mystery.
Old 25th Jan 2019, 3:04 pm   #1978
another 7mk2 metal case found on the internet
SERIAL 3418-A-367-M
Name:	Captura de pantalla 2019-01-25 a las 14.02.32.jpg
Old 26th Jan 2019, 3:07 pm   #1979
Sinewave
Sinewave's Avatar
With thanks to Studio263 who kindly donated to me an Avometer Model 7, serial No.39538-A-253.
This meter has some lovely history belonging previously to the RAE based at Farnborough. It has the aluminium rear casing and is still in perfect working order.
It comes with a set of orginal leads with the NSN and a case with the lettering ZD. 00207.
What a beautiful example of a mark 1 Avometer Model 7 this is.
Old 27th Jan 2019, 12:20 pm   #1980
Avo 8 mk3 find on a famous web metal battery cover
serial nÂș 37760.266
Name:	Captura de pantalla 2019-01-27 a las 11.19.06.png
