29th Jul 2018, 11:35 am | #1 |
Hacker Herald RP37A repair
I attended the Cumbria Steam Gathering yesterday, of course the first part of the site to visit is the jumble.
A dealer had a couple of Hackers that I just could not refuse at £5 each, I didn't even try to haggle. One was a Helmsman, which works on all bands except SW 2 & 3, but that is another story, as it is in need of some TLC I've started on the Herald firstly. First of all just a simple cosmetic clean, some switch cleaner and lube the aerial. I replaced one of the damaged battery connectors and powered it up then on the shop PSU. Working, but distorted audio at 18v and about 200mA being drawn. I set about setting up as per the manual, but no joy, I found that T1 BC148 faulty, so replaced this. Still the same fault, inspection of RV3 47k trimmer had the rivet missing on one of the terminals, this was replaced and could now get more sensible voltage readings around T1. But the amp was drawing way too much current adjusting RV4 I still had around 50mA drawn quiescent at minimum setting and a lot of noise. I went for the freezer spray, but found the can to be empty so started pushing a hot iron on to components, eventually found what appears to be the culprit, T3 OC71, I've not got one of these (Can anyone let me know the best use in it's place) I've put in a AC128 in for now. The noise has improved, but still have about 40mA draw and the RV4 still not working correctly. So for now, I've boxed it back up as it's sort of working and will do a more though restoration in the future. One of the tone control knobs has a broken centre, is there any wisdom as to how repair this, maybe fill with modellers clay, then push in a shaft and let it set. Last edited by NickG0HIK; 29th Jul 2018 at 11:52 am. |
29th Jul 2018, 11:56 am | #2 |
Re: Hacker Herald RP37A repair
I expect Mr. Hennessy will be along soon.......
Otherwise, if you fancy a bomb proof upgrade, here's what I did: https://vintage-radio.net/forum/showthread.php?t=54342 You may well have a whiskery output transistor or leaky capacitor somewhere- you've sorted the dodgy pots. T3 does thermal compensation for the output stage- pretty much any small signal Ge PNP will do.
29th Jul 2018, 12:12 pm | #3 |
Thanks for the info, if it keeps raining today, I may have another go at the set later in the day.
I'd never have thought about the Polystyrene cap being a fault in yours, but I have had these faulty myself in the past. I'll check that and the output transistors too. |
29th Jul 2018, 12:44 pm | #4 |
Thanks, Chris, I've got an AM herald and a Sovereign 2 to do shortly. The cosmetics are done on the Herald, I just have to make it speak again.
For the broken knob, I'd turn down a metal knob, or a brass insert and araldite it in. David
29th Jul 2018, 1:22 pm | #5 | |
I see you've found another bad Lockfit. Rip 'em out I say! They're little ticking time bombs |
29th Jul 2018, 3:16 pm | #6 |
AC128's and BC148's are two types of transistor that I seem to have plenty of in my stores
29th Jul 2018, 3:21 pm | #7 |
29th Jul 2018, 3:24 pm | #8 |
I wouldn't use NOS Lockfits for anything. Remember a BC108/BC548 is exactly the same as a BC148 and will drop straight in. In fact any Si NPN general purpose type is likely to be fine.
I wasn't joking about ripping them out. I see so many failed Lockfits nowadays that they have become a change on sight item. They are normally cheap and easy to replace. |
29th Jul 2018, 4:25 pm | #9 |
Ok Thanks for the information, all noted.
29th Jul 2018, 4:27 pm | #10 | |
A nice repair that only took a few minutes to complete. |
29th Jul 2018, 5:34 pm | #11 |
Hello,
40mA is still too much. You may have a leaky electrolytic. Can the quiescent current be set correctly at the link or is it too high? If not then the likely candidates are the output pair. Can the midpoint be set correctly with rv 3? If not then t4 is faulty. AC 128 is ok for t3. John. Ps I have two knobs if you want them. Last edited by john.north; 29th Jul 2018 at 5:35 pm. Reason: Control knobs |
29th Jul 2018, 8:17 pm | #12 |
Fashionably late, as always
Good advice given so far. It might be worth checking T4, as that can cause strange faults. It's possible the output devices are leaking - especially if they've been over-heated for some time. To test for this, temporarily short the two bases together. The quiescent current (via the test link) should drop to nothing in this state - if not, try replacing the output devices. Good luck, Mark |
