9th Sep 2022, 3:35 pm | #21 |
Re: Akai 1710W as a tube amp
Very few people, when recording something would want loudspeakers operating blaring out the signal from the microphones. It would create howl-round like a badly set-up public address system. At a minimum, there will be changes to the frequency response, with a 3-head machine doing off-tape monitoring, there would be echoes.
So it's not surprising that the Akai mutes the speakers during 'Record' mode. In other modes, the microphone preamplifiers are off. So having the machine configured to put sound from any input straight through the speakers will need an amount of re-wiring in the switches of the machine. If you still intend keeping the machine, it's a lot less trouble to just pick up another amplifier. You could even survive listening with something with transistors in it, until your fancy amplifier gets fixed. David
10th Sep 2022, 9:16 am | #22 | |
Btw do you know if the headphone out is stereo or mono. I have the original headphones and the connection jack seems to be TRS. The volume control individually controls both left and right speakers. I plugged in an adapter TRS to dual female but when both speakers are plugged in the left and right volume control affects both speakers |
10th Sep 2022, 10:01 am | #23 |
Headphones output socket is stereo as per the schematic, if you wanted to use the headphone socket to connect your loudspeakers to you'll have to bypass the two 220 Ohm power limiting resistors otherwise you you'll only get minimal power to the loudspeakers.
Lawrence. Last edited by ms660; 10th Sep 2022 at 10:20 am. Reason: clarify |
10th Sep 2022, 7:05 pm | #24 | |
13th Sep 2022, 11:38 am | #25 | |
There two versions of the Akai 1710. One uses 6BM8/ECC82 as driver/outputs with ss rectifier, other one has 6AR5 as output, ECC83 driver and valve rectifier. Which version is yours? To convert into a stand alone amp, remove the tape mechanism and the PCB that carries the tape preamp circuitry. The output of this board is connected to the volume or tone control, sorry I forgot exactly where it goes. Anyway, you connect a shielded cable from the input RCA to the same point and that is it. If the tape section is to be retained, a switch can be rigged to give the line in input directly to the volume control, bypassing the tape amp board. The tape section is nothing great. The mechanism and circuit are vastly inferior compared to the previous valve based R2R from Akai, the M8. BTW, I replied to this query on another forum recently. Was that you? Regards,
Anwesh |
17th Sep 2022, 4:06 am | #26 |
So I ended up actually getting it to work by simply soldering wire from each input to the volume control thus bypassing the SS preamp. Must say for a 4W amp sounds really great and it still plays the tapes
19th Sep 2022, 11:56 pm | #27 |
A four watt amp in the 1960's was considered to be loud in the domestic
environment and even on stage It it works for you that's good nirvana. The speaker and cabinet could often make the difference, not just the wattage! Dave W |
24th Sep 2022, 3:04 am | #28 |
Yeah 4W is loud indeed and in my case they are hooked up to some classical Wharfedale E-30s at 94dB sensitivity.
