Old 6th Sep 2022, 9:29 am   #1
theredhouseinn
theredhouseinn's Avatar
Default Farnell FG1 Function Generator.
Diodes went s/c and burnt out the mains tx.
I have repaired the former and rewound with new wire.
Now the difficult bit, how to clean off the pitch and varnish from the lams.
I have tried petrol, parrafin, white spirit, acetone, and in the ultrasonic cleaner at 70 degees, but none will shift the crud.
Has anyone successfully cleaned lams without damaging them?
John.
theredhouseinn is offline
Old 7th Sep 2022, 5:46 am   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Farnell FG1 Function Generator.
I used a low heat oven, petrol and elbow grease to good effect in the past. Have also used Nitromorse, luckily had some old formula stuff.
Andy.
Old 10th Sep 2022, 4:50 pm   #3
theredhouseinn
Thanks Andy.
The old memory needs a jog sometimes, I have a can of nitromorse in the cupboard.
I soaked the lams in it for 24 hours, brushed them off in water with a tooth brush, soaked them in wd40 for a day, got all the lams back in except for a damaged one when I took them out.
Stuck the mains on it, 22 volts spot on.
John.
