Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
14th Feb 2024, 9:01 am | #1 |
0.15" 3.81mm edge connectors wanted
Hi there,
I'm trying to find some edge connectors in the rare 0.15" (3.81mm) pitch for some audio equipment modules. 0.156" (3.96mm) and 0.1" (2.54mm) are the common pitch that are widely available but I'm really struggling to find 0.15" ones! Ideally need 40 pin ones but smaller ones may be useful. Thanks, Mark |
14th Feb 2024, 10:40 am | #2 |
Re: 0.15" 3.81mm edge connectors wanted
Not 40 pin but 22 - I have some Amphenol 143-022-04
They measure about right with a vernier but it's easy to loose 6 thou - perhaps you can find out if they suit you on line? Edit to add - I am a dunce. Mine are 83mm over the end pins, not 80. So no good to you!
"The best dBs, come in 3s" - Woody Brown |
14th Feb 2024, 12:10 pm | #3 |
Mouser have loads of 3.81mm edge connectors, even if not stocked, they can be ordered, example;
https://www.mouser.co.uk/ProductDeta...blnPJxHg%3D%3D Datasheet for 3.81mm edge connectors. https://www.mouser.co.uk/datasheet/2...er-2498050.pdf David |
14th Feb 2024, 9:15 pm | #4 |
Is it the male or female connector which you need? If the male, I have some plug in 0.15" veroboard which I will be quite happy to cut the ends off for you.
Rod |
14th Feb 2024, 10:27 pm | #5 |
Single or double sided?
There is a good chance that I will have something but cannot check until the week after next. If you don’t find anything bump the enquiry so that it comes back to the top. |
4th Mar 2024, 9:49 pm | #6 |
Hi Mark, sorry for the delay, I decided to spend an extra week in the sun.
These cost me a small fortune and I know I will regret selling them, a PCB repair job is bound to turn up as soon as they are gone. I can spare 3 single sided 18 way with detachable feet, you can have all 3 for £15 inc post I also have 2 single sided 32 way with moulded feet which you can have for £30 inc post. |
