Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
3rd Nov 2023, 1:01 pm | #1 |
2.5ohm loudspeaker
Hello all
I am looking for a 8 or 10" size of the above. Regards to all Ian Rose |
4th Nov 2023, 2:55 pm | #2 |
Re: 2.5ohm loudspeaker
Er, what's wrong with a more readily found 3 ohm unit?
Edward. |
5th Nov 2023, 10:44 am | #3 |
It probably is a 3 ohm unit. The DC resistance of the coil will measure about 2.5 ohms. 3 ohms refers to the impedance (AC resistance) measured at 1khz.
5th Nov 2023, 6:07 pm | #4 |
Given the variations of impedance a loudspeaker gives across the audio band and that valve amplifiers are more tolerant of lower impedances than of higher impedances, 3 Ohms ought to be fine in most instances.
2.5 ohms may be a clue as to the use. I remember that AR88 documentation calls up the use of a 2.5 Ohm speaker. David
6th Nov 2023, 6:35 pm | #5 | |
6th Nov 2023, 6:59 pm | #6 |
I have an 8" unit if it's any use to you.
David. |
7th Nov 2023, 10:39 am | #7 |
7th Nov 2023, 1:00 pm | #8 |
P.M. Received,
speaker being checked prior to despatch. David. |
8th Nov 2023, 6:33 pm | #9 |
Mr Moderator
Thread can now be closed as far as i am concerned. Regards Ian Rose |
