27th Feb 2014, 3:03 pm | #1 |
BNC interchangeable?
As the Dutch Wikipedia claims interchanging RG58 with RG59 (50 Omms to 75 Ohms)would give irretrievable damage,it makes me worry about.
They suggest that the dimensions differ too much. Is this true ? Swapping them is something I do all the time. Half of the test equipment is Philips (75 Ohm) and the other half US (50 Ohms) Only used in AM and FM sets. The cables are short (max. 1 meter),but these are also mixed. Jard N. |
27th Feb 2014, 4:34 pm | #2 |
Re: BNC interchangeable?
I have not found that ; RG58=UR76, RG59=UR70 british cable types.
The only thing you might damage is a 75 ohm bnc socket, if you try to insert a 50 ohm plug, which has a larger pin |
27th Feb 2014, 4:40 pm | #3 | |
27th Feb 2014, 4:49 pm | #4 |
I have always understood that 50 and 75 can be put together without any mechanical damage. The problems occur in the mismatch of impedances.Ref the article:
http://www.milestek.com/blog/index.p...ors-explained/ Malcolm |
27th Feb 2014, 5:30 pm | #5 |
I have always understood the 75 ohm BNC had a fatter pin and would therefore cause damage to the 50 ohm socket. In fact we had a case of a 50 ohm socket on a transmitter duplexer which had exactly that type of problem. The pin apparently is fatter nearer the cable entry end i.e. more conical and wider where it enters the plastic insulation. But I may stand to be corrected.....
Alan. |
27th Feb 2014, 6:10 pm | #6 |
IMVHO one difference exists, because of cable different thickness only, Russians have bit different design of this kind of coupling.
27th Feb 2014, 7:45 pm | #7 |
Something like this?
Picture:see attachement Besides,this afternoon while I was searching at Google,I even found a link to this site: https://www.vintage-radio.net/forum/...ad.php?t=47357 Jard N |
27th Feb 2014, 9:44 pm | #8 |
BNC does 75/50 Ohm variants by removing dielectric
N does 75/50 ohm variants by changing the diameter of the centre pin (and 75 ohm females are ruined by 50 Ohm males) SMB and SMC do 75 and 50 Ohm variants with the same centre pin, but different outside diameters. So all three games have been played. David
27th Feb 2014, 10:10 pm | #9 |
I just checked some of my 1980's electronics catalogues. They explicitly state that (for Radiall and Greenpar at least) 75 and 50 Ohm BNC connectors are mechanically interchangeable, but the corresponding N types are not.
27th Feb 2014, 11:09 pm | #10 |
Luckily it´s very obvious to see for N-types.
N connector is a threaded RF connector and commonly is used to join with coaxial cable. N connector was invented in 1940’s and comes in 50 ohm and 75 ohm impedance. The 50 ohm N connector is widely used in the infrastructure of wireless base station and cellular base station, and the working frequency normally is from hundred MHz to 5.8GHz. The 75 ohm N connector can work up to 1.5GHz, and is primarily used in the infrastructure of cable TV systems. Mechanical Feature: N male Inner thread of 5/8-24UNEF-2B, Inner diameter is from 14.732mm to 14.986mm An air gap between centre and outer contacts Outer diameter range is 19.5mm ~ 21.0mm Silicon Rubber O-ring inside Male centre contact has dia. 1.60mm ~ 1.68mm for 50 ohm N male ; dia. 0.87mm ~ 0.91mm for 75 ohm N male Jard N. |
4th Mar 2014, 12:11 pm | #11 |
One other difference I have found in the past is that the o.d. of RG59 cable is v. slightly greater than RG58. This makes the fitting of the clamp section of the plug/socket difficult to impossible.
Just my penny's worth from experience |
10th Mar 2014, 12:19 am | #12 |
I have found the only difference in the BNC connectors for RG 58 and 59 to be the outside diameter of the cable itself.
I have yet to see a center pin size difference here in the USA. On most of my test equipment I do try to use the factory specified cable, but in reality have found little difference between the two types for test leads. But on the capacitor tester it did make a measurable difference, as it should. On PL259's, it's the insert that goes into the back of the connector that is a different size. One each of 3 different sizes for RG58, 58X, and 59. |
